[petsc-dev] Error: 'ooc_nb_file_type' at (1) is not a member of the 'cmumps_struc' structure
    Satish Balay
    balay at mcs.anl.gov
    Mon Sep 28 11:47:29 CDT 2015
Its best to install different versions of software collection in
different prefix locations - to avoid such conflicts.
/home/chaffra/Projects/FEniCS/v1
/home/chaffra/Projects/FEniCS/v2
or some other naming convention...
Satish
On Mon, 28 Sep 2015, Chaffra Affouda wrote:
> OK, after removing everything (mumps+suitesparses files) in include folder as
> suggested by Satish's response it finally builds mumps. There must have been
> some conflicting mumps files in the include folder.
> Thanks,
> Chaffra
> On 09/28/2015 10:11 AM, Satish Balay wrote:
> > > Configure Options: --configModules=PETSc.Configure
> > > --optionsModule=config.compilerOptions
> > > --prefix=/home/chaffra/Projects/FEniCS COPTFLAGS=-O2 --with-debugging=1
> > > --with-shared-libraries=1 --with-clanguage=cxx --with-c-support=1
> > > --with-pthreadclasses=1 --with-openmp=1 --download-suitesparse=1
> > > --download-hypre=1 --download-mumps=1 --download-scalapack=1
> > > --download-blacs=1 --download-ptscotch=1 --download-scotch=1
> > > --download-metis=1 --download-parmetis=1 --download-petsc4py=1
> > > --download-mpi4py=1
> > What do you have for:
> > ls /home/chaffra/Projects/FEniCS/include
> > Also suggest not using:
> > --with-clanguage=cxx --with-c-support=1 --with-pthreadclasses=1
> > --with-openmp=1
> > And there is no more option '--download-blacs=1'
> > Satish
> > > Hi Barry,
> > > I've erased everything under petsc, clone from git but mumps still won't
> > > build. Attached is my configure.log.
> > > Thanks,
> > > Chaffra
> > > On 09/25/2015 04:51 PM, Barry Smith wrote:
> > > >     Cannot explain this. Try deleting the entire PETSc directory and
> > > > running
> > > > again with --download-mumps send configure.log if it fails
> > > >     Barry
> > > > > On Sep 25, 2015, at 3:29 PM, Chaffra Affouda<chaffra at gmail.com>
> > > > > wrote:
> > > > > Hi,
> > > > > I cannot build petsc-3.6.1 on ubuntu. I am getting the error below. Is
> > > > > mumps broken here? I am using ubuntu trusty.
> > > > > make[1]: Leaving directory
> > > > > `petsc-3.6.1/arch-linux2-cxx-opt/externalpackages/MUMPS'mumps_io_basic.c:
> > > > > In function ‘mumps_init_file_name’:
> > > > > mumps_io_basic.c:579:14: warning: assignment discards ‘const’
> > > > > qualifier
> > > > > from pointer target type [enabled by default]
> > > > >         tmp_dir=MUMPS_OOC_DEFAULT_DIR;
> > > > > cmumps_ooc.F:159.42:
> > > > > OOC_NB_FILE_TYPE=id%OOC_NB_FILE_TYPE
> > > > >                                            1
> > > > > structure
> > > > > cmumps_ooc.F:525.36:
> > > > >           DO I1=1,id%OOC_NB_FILE_TYPE
> > > > >                                      1
> > > > > structure
> > > > > cmumps_ooc.F:540.12:
> > > > > ENDDO
> > > > >              1
> > > > > Error: Expecting END IF statement at (1)
> > > > > cmumps_ooc.F:562.31:
> > > > >        IF(.NOT. id%IF_RESTARTING) CALL CMUMPS_OOC_CLEAN_FILES(id,IERR)
> > > > >                                 1
> > > > > Error: 'if_restarting' at (1) is not a member of the 'cmumps_struc'
> > > > > structure
> > > > > cmumps_ooc.F:677.42:
> > > > >                                            1
> > > > > structure
> > > > > make[3]: *** [cmumps_ooc.o] Error 1
> > > > > make[2]: *** [c] Error 2
> > > > > make[1]: *** [mumps_lib] Error 2
> > > > > make: *** [c] Error 2
