[petsc-dev] Error: 'ooc_nb_file_type' at (1) is not a member of the 'cmumps_struc' structure
Mon Sep 28 09:11:15 CDT 2015
> Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --prefix=/home/chaffra/Projects/FEniCS COPTFLAGS=-O2 --with-debugging=1 --with-shared-libraries=1 --with-clanguage=cxx --with-c-support=1 --with-pthreadclasses=1 --with-openmp=1 --download-suitesparse=1 --download-hypre=1 --download-mumps=1 --download-scalapack=1 --download-blacs=1 --download-ptscotch=1 --download-scotch=1 --download-metis=1 --download-parmetis=1 --download-petsc4py=1 --download-mpi4py=1
What do you have for:
ls /home/chaffra/Projects/FEniCS/include
Also suggest not using:
And there is no more option '--download-blacs=1'
Satish
On Mon, 28 Sep 2015, Chaffra Affouda wrote:
> Hi Barry,
> I've erased everything under petsc, clone from git but mumps still won't
> build. Attached is my configure.log.
> Thanks,
> Chaffra
> On 09/25/2015 04:51 PM, Barry Smith wrote:
> >    Cannot explain this. Try deleting the entire PETSc directory and running
> > again with --download-mumps send configure.log if it fails
> >    Barry
> > > On Sep 25, 2015, at 3:29 PM, Chaffra Affouda<chaffra at gmail.com>  wrote:
> > > Hi,
> > > I cannot build petsc-3.6.1 on ubuntu. I am getting the error below. Is
> > > mumps broken here? I am using ubuntu trusty.
> > > make[1]: Leaving directory
> > > `petsc-3.6.1/arch-linux2-cxx-opt/externalpackages/MUMPS'mumps_io_basic.c:
> > > In function ‘mumps_init_file_name’:
> > > mumps_io_basic.c:579:14: warning: assignment discards ‘const’ qualifier
> > > from pointer target type [enabled by default]
> > >        tmp_dir=MUMPS_OOC_DEFAULT_DIR;
> > > cmumps_ooc.F:159.42:
> > > OOC_NB_FILE_TYPE=id%OOC_NB_FILE_TYPE
> > >                                           1
> > > structure
> > > cmumps_ooc.F:525.36:
> > >          DO I1=1,id%OOC_NB_FILE_TYPE
> > >                                     1
> > > structure
> > > cmumps_ooc.F:540.12:
> > > ENDDO
> > >             1
> > > Error: Expecting END IF statement at (1)
> > > cmumps_ooc.F:562.31:
> > >       IF(.NOT. id%IF_RESTARTING) CALL CMUMPS_OOC_CLEAN_FILES(id,IERR)
> > >                                1
> > > Error: 'if_restarting' at (1) is not a member of the 'cmumps_struc'
> > > structure
> > > cmumps_ooc.F:677.42:
> > >                                           1
> > > structure
> > > make[3]: *** [cmumps_ooc.o] Error 1
> > > make[2]: *** [c] Error 2
> > > make[1]: *** [mumps_lib] Error 2
> > > make: *** [c] Error 2
