[petsc-dev] broken options handling with intel 16.0 compilers on mac OS
    Satish Balay
    balay at mcs.anl.gov
    Tue Sep 22 15:50:04 CDT 2015
I'm not sure what to suggest.
Blaise gets a successful build with:
--with-cxx=0 --with-clib-autodetect=0 --with-fortranlib-autodetect=0 LIBS="/opt/intel-16.0/compilers_and_libraries_2016.0.083/mac/compiler/lib/libifcore.a"
The next thing Blaise could try is:
--with-cxx=0 --with-clib-autodetect=0 --with-fortranlib-autodetect=0 LIBS=-lifcore
[and if this fails - see which ifcore the binary is using - via 'otool -l petscbinary |grep ifore']
If not - what I would do - is try compiling an example with a petsc makefile.
[with the broken build]
And then copy/paste the link line - removing stuff - until the binary
created by that link line works. [and identify the linker option is
making the difference]. Again - this would be for Blaise to try.
Intel compilers (esp on Mac) had workarrounds to system issues encoded
in the link command. [I remember the first generation of intel
compilers on Mac had such issues]. And the way PETSc configure, and
checkFortranLibraries() process/use this 'ifort -v' info can break
these encoded workarrounds.. [Its a hacky piece of code - and not easy
to get right]
Ideally compilers should provide equivalent of 'mpicc -show' - so that
configure tools can grab and use this info for language interoperable
linking.
[Jed suggested we should 'always use FC as linker' and not do any such
detection.  But then we still have to worry about C++. Previously we
had machines where we had to use C++ linker - but perhaps such
machines don't exist anymore]
Satish
On Tue, 22 Sep 2015, Richard Mills wrote:
> Blaise and Satish,
> I'm a bit slow to pick up on this thread as I was busy traveling, but since
> I use a Mac and work for Intel, I thought I should see if I could reproduce
> the problems that Blaise is seeing.  I installed the 16.0 compilers and
> built a simple configuration ('--with-debugging=1 COPTFLAGS="-g -O0"
> FOPTFLAGS="-g -O0" CXXOPTFLAGS="-g -O0"
> --with-blas-lapack-dir=/opt/intel/compilers_and_libraries_2016/mac/mkl
> --with-mpi-dir=/Users/rtmills/packages/mpich-3.1.4-intel') using a very
> recent revision of 'master' (09b4d96fa5749f82a0af9a914729f77a4ef2b2fd, Sun
> Sep 20 22:51:31 2015 -0500).  When I try running SNES ex5f and passing
> various command-line options, everything appears to work fine.  Any
> suggestions for digging deeping into this to try to determine the
> difference between what Blaise and I are seeing?
> Best regards,
> Richard
> On Mon, Sep 21, 2015 at 10:21 AM, Blaise A Bourdin <bourdin at lsu.edu> wrote:
> > > On Sep 20, 2015, at 9:04 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > Hm - I would suggest doing a minimal build build with:
> > > --with-cxx=0
> > > And see if that makes a difference.
> > Satish,
> > It does help.
> > Turning off auto detect leads to a functional build, turning it back on
> > leads to a non-functioning one.
> > The configure.log without auto detect is here:
> > https://filestogeaux.lsu.edu/public/download.php?FILE=bourdin/61967j4XaVp
> > The one with auto detect there:
> >    https://filestogeaux.lsu.edu/public/download.php?FILE=bourdin/691pPOSRU
> > The petscconf.h are attached
