[petsc-dev] Nested event logging and human friendly output
    Matthew Knepley
    knepley at gmail.com
    Mon Sep 14 07:50:42 CDT 2015
On Mon, Sep 14, 2015 at 7:45 AM, Koos Huijssen <koos.huijssen at vortech.nl>
wrote:
> Dear PETSc development team,
> We have developed an extension of the PETSc event logging facilities that
> has the following advanced features:
> - It allows logging of events in the form of a nested tree. So if some
> function is called from multiple locations in the code, these instances are
> distinguished. This in contrast with the standard event logger, which only
> logs the amount of total call time.
How is this different from using stages?
> - It allows the output report to be formatted in XML format. This output
> can then be viewed in a human-friendly form in a web browser
>  with the use of the XSL Transformation script performance_xml2html.xsl.
> The html features an nested timings tree that can be expanded and collapsed
> as desired.
This sounds fine and useful. We will look at the code.
     Matt
> This tool has been very useful for us to analyze the code and pinpoint
> performance bottle necks. We think that it can be useful for others as
> well, and therefore we are providing the code here for integration in the
> open source distribution of PETSc.
> For more information I refer to the included manual. We have also provided
> a test program and a makefile for convenience. The test program can be run
> using MPI with for instance 3-6 processes.
> I apologize for not using the git repo to submit the developed code. I
> also apologize for not adhering to the PETSc coding standards (or at least
> not as far as I know), but I hope that it is not too far off.. Apart from
> the whole capital/underscore standardization stuff one issue may require
> special attention, namely the (ab)use of the format PETSc_VIEWER_ASCII_IMPL
> for signaling the XML format in XMLViewer.c. I couldn't find an already
> existing and better fitting format, but it could be necessary to add a new
> format here for this purpose.
> Can you take it up from here and realize the integration of the code in
> the PETSc distribution?
> With kind regards,
> Koos Huijssen
> ____________________________________________________________________
> VORtech BV - Scientific software engineers
> Dr.ir. Koos Huijssen
> P.O. Box 260
> 2600 AG Delft
> The Netherlands
> phone  +31(0)15-285 0125
> mobile +31(0)6-3333 0803
> email koos.huijssen at vortech.nl
> web   www.vortech.nl
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150914/82a338d7/attachment.html>
