[petsc-dev] [petsc-checkbuilds] PETSc blame digest (next)	2015-09-08
    Barry Smith
    bsmith at mcs.anl.gov
    Thu Sep 10 01:08:26 CDT 2015
  Satish,
   I've done all this and then made a new series of corrections to the branch that hopefully won't break too much more.
   Thanks
  Barry
> On Sep 8, 2015, at 11:44 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Barry,
> I amended this commit - and removed that section of code, and pushed
> my change. [to pr352/dmay/pctelescope/master and merged to next]
> [I did this ammend - as this commit didn't propogage to next or master]
> [Assuming you haven't added anything else to this branch] Can you do
> the following - to get this 'amended' commit cleanly - and discard the
> previous commit in your branch.
> git checkout pr352/dmay/pctelescope/master
> git fetch
> git reset --hard origin/pr352/dmay/pctelescope/master
> Thanks,
> Satish
> On Tue, 8 Sep 2015, Barry Smith wrote:
>>  Satish,
>>   Likely it is wrong. I was forced by git to do some strange merge that produced that result. I can't explain why it happened.
>>   Feel free to fix the branch and master
>>  Barry
>>> On Sep 8, 2015, at 11:25 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>> Barry,
>>> I don't understand the commit https://bitbucket.org/petsc/petsc/commits/3dcc747d65aa2f2e79d189bef52568da19b89eea
>>> -PetscErrorCode PCTelescopeSetIgnoreDM(PC pc,PetscBool v)
>>> +PetscErrorCode PCTelescopeSetIgnoreDM(PC pc,PetscInt v)
>>>  PetscTryMethod(pc,"PCTelescopeSetIgnoreDM_C",(PC,PetscBool),(pc,v));
>>>  return(0);
>>> This reverts the change I made earlier - which was required to compile
>>> code [otherwise (PetscBool)(PetscInt) is flaged as compiler error]
>>>>>>> -PETSC_EXTERN PetscErrorCode PCTelescopeSetIgnoreDM(PC,PetscInt);
>>>>>>> +PETSC_EXTERN PetscErrorCode PCTelescopeSetIgnoreDM(PC,PetscBool);
>>>>>>> -PetscErrorCode PCTelescopeSetIgnoreDM(PC pc,PetscInt v)
>>>>>>> +PetscErrorCode PCTelescopeSetIgnoreDM(PC pc,PetscBool v)
>>> Satish
>>>>  Done. But I may have messed up the history a little
>>>>> On Sep 8, 2015, at 4:28 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>>>> Barry,
>>>>> I see you made some changes to pr352/dmay/pctelescope/master and merged to next [and pushed]
>>>>> However - you did not push pr352/dmay/pctelescope/master. Could you push this branch?
>>>>> I have fix for the following warnings - and would like to push my changes..
>>>>> [Just want to make sure all changes are in sync]
>>>>> thanks,
>>>>> Satish
>>>>> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCTelescopeGetKSP':
>>>>> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:654: warning: statement with no effect
>>>>> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCTelescopeGetReductionFactor':
>>>>> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:675: warning: statement with no effect
>>>>> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCTelescopeSetReductionFactor':
>>>>> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:696: warning: statement with no effect
>>>>> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCTelescopeGetIgnoreDM':
>>>>> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:717: warning: statement with no effect
>>>>> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCTelescopeSetIgnoreDM':
>>>>> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:738: warning: statement with no effect
>>>>> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCTelescopeGetDM':
>>>>> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:759: warning: statement with no effect
>>>>> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCSetUp_Telescope':
>>>>> /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:352: warning: 'subcomm' may be used uninitialized in this function
>>>>> On Tue, 8 Sep 2015, Satish Balay wrote:
>>>>>> Ok - pushed to pr352/dmay/pctelescope/master - and merged to next
>>>>>> https://bitbucket.org/petsc/petsc/commits/bfd6bcc6ac8e2f0022fa8b00b8cd29f3a32cf260
>>>>>> [please before further changes - or merge to master]
>>>>>> Satish
>>>>>>> I haven't check the examples - but I have the following fix for the build. Will push now
>>>>>>> Satish
>>>>>>> diff --git a/include/petscpc.h b/include/petscpc.h
>>>>>>> index 7e583b8..0cddc86 100644
>>>>>>> --- a/include/petscpc.h
>>>>>>> +++ b/include/petscpc.h
>>>>>>> @@ -324,7 +324,7 @@ PETSC_EXTERN PetscErrorCode PCMGResidualDefault(Mat,Vec,Vec,Vec);
>>>>>>> PETSC_EXTERN PetscErrorCode PCTelescopeGetReductionFactor(PC,PetscInt*);
>>>>>>> PETSC_EXTERN PetscErrorCode PCTelescopeSetReductionFactor(PC,PetscInt);
>>>>>>> PETSC_EXTERN PetscErrorCode PCTelescopeGetIgnoreDM(PC,PetscBool*);
>>>>>>> PETSC_EXTERN PetscErrorCode PCTelescopeGetDM(PC,DM*);
>>>>>>> #endif /* __PETSCPC_H */
>>>>>>> diff --git a/src/ksp/pc/impls/telescope/telescope.c b/src/ksp/pc/impls/telescope/telescope.c
>>>>>>> index 5e899de..fe75c46 100644
>>>>>>> --- a/src/ksp/pc/impls/telescope/telescope.c
>>>>>>> +++ b/src/ksp/pc/impls/telescope/telescope.c
>>>>>>> @@ -207,7 +207,7 @@ PetscErrorCode PCTelescopeMatCreate_default(PC pc,PC_Telescope sred,MatReuse reu
>>>>>>>   if (reuse != MAT_INITIAL_MATRIX) { Bred = *A; }
>>>>>>>   ierr = MatGetSize(Blocal,&mm,NULL);CHKERRQ(ierr);
>>>>>>> -    //ierr = MatCreateMPIMatConcatenateSeqMat(subcomm,Blocal,PETSC_DECIDE,reuse,&Bred);CHKERRQ(ierr);
>>>>>>> +    /* ierr = MatCreateMPIMatConcatenateSeqMat(subcomm,Blocal,PETSC_DECIDE,reuse,&Bred);CHKERRQ(ierr); */
>>>>>>>   ierr = MatCreateMPIMatConcatenateSeqMat(subcomm,Blocal,mm,reuse,&Bred);CHKERRQ(ierr);
>>>>>>> *A = Bred;
>>>>>>> @@ -734,7 +734,7 @@ PetscErrorCode PCTelescopeGetIgnoreDM(PC pc,PetscBool *v)
>>>>>>> .keywords: PC, telescoping solve
>>>>>>> return(0);
>>>>>>> diff --git a/src/ksp/pc/impls/telescope/telescope_dmda.c b/src/ksp/pc/impls/telescope/telescope_dmda.c
>>>>>>> index edd1708..98d0c7f 100644
>>>>>>> --- a/src/ksp/pc/impls/telescope/telescope_dmda.c
>>>>>>> +++ b/src/ksp/pc/impls/telescope/telescope_dmda.c
>>>>>>> @@ -757,7 +757,7 @@ PetscErrorCode PCTelescopeMatCreate_dmda(PC pc,PC_Telescope sred,MatReuse reuse,
>>>>>>>   if (reuse != MAT_INITIAL_MATRIX) {Bred = *A;}
>>>>>>> *A = Bred;
>>>>>>>> Dave,
>>>>>>>>  I'll be fixing these.
>>>>>>>> Barry
>>>>>>>>> On Sep 8, 2015, at 9:00 AM, PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov> wrote:
>>>>>>>>> Dear PETSc developer,
>>>>>>>>> This email contains listings of contributions attributed to you by
>>>>>>>>> `git blame` that caused compiler errors or warnings in PETSc automated
>>>>>>>>> testing.  Follow the links to see the full log files. Please attempt to fix
>>>>>>>>> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are unable
>>>>>>>>> to resolve the issues.
>>>>>>>>> Thanks,
>>>>>>>>> The PETSc development team
>>>>>>>>> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/6ab51f8
>>>>>>>>> PCSemiRedundant:
>>>>>>>>> src/ksp/pc/impls/telescope/telescope.c:116
>>>>>>>>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-pkgs-opt_crank.log]
>>>>>>>>>   /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope.c:116:3: warning: 'subdm' may be used uninitialized in this function [-Wmaybe-uninitialized]
>>>>>>>>> src/ksp/pc/impls/telescope/telescope.c:210
>>>>>>>>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-c89_thrash.log]
>>>>>>>>>   /sandbox/petsc/petsc.clone-2/src/ksp/pc/impls/telescope/telescope.c:210:5: error: expected expression before '/' token
>>>>>>>>> src/ksp/pc/impls/telescope/telescope.c:380
>>>>>>>>>   /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope.c:380:12: warning: 'subcomm' may be used uninitialized in this function [-Wmaybe-uninitialized]
>>>>>>>>> src/ksp/pc/impls/telescope/telescope_dmda.c:112
>>>>>>>>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-opt-cxx-quad_cg.log]
>>>>>>>>>   /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:112:18: warning: 'start_IJK' may be used uninitialized in this function [-Wmaybe-uninitialized]
>>>>>>>>>   /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:112:7: warning: 'start_IJK' may be used uninitialized in this function [-Wmaybe-uninitialized]
>>>>>>>>> src/ksp/pc/impls/telescope/telescope_dmda.c:535
>>>>>>>>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-c-exodus-dbg-builder_bb-proxy.log]
>>>>>>>>>   /sandbox/balay/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>>>>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-gcc-ifc-cmplx_crank.log]
>>>>>>>>>   /sandbox/petsc/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>>>>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-pkgs-valgrind_grind.log]
>>>>>>>>>   /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>>>>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-cuda_bb-proxy.log]
>>>>>>>>>   /sandbox/balay/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>>>>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-pkgs-64idx_thrash.log]
>>>>>>>>>   /sandbox/petsc/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>>>>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-freebsd-cxx-cmplx-pkgs-dbg_wii.log]
>>>>>>>>>   /home/balay/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>>>>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-pkgs-threadcomm_thrash.log]
>>>>>>>>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-gcc-pgf90_grind.log]
>>>>>>>>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-uni_crush.log]
>>>>>>>>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-linux-dbg-quad_churn.log]
>>>>>>>>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-viennacl_bb-proxy.log]
>>>>>>>>>   /sandbox/balay/petsc.clone-4/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>>>>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_arch-cuda-double_bb-proxy.log]
>>>>>>>>>   /sandbox/balay/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>>>>> src/ksp/pc/impls/telescope/telescope_dmda.c:609
>>>>>>>>>   /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>>>>>   /sandbox/petsc/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>>>>>   /sandbox/balay/petsc.clone-4/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>>>>>   /sandbox/balay/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>>>>>   /sandbox/balay/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>>>>>   /home/balay/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>>>>>   /sandbox/petsc/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>>>>>   /sandbox/balay/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
>>>>>>>>> src/ksp/pc/impls/telescope/telescope_dmda.c:760
>>>>>>>>>   /sandbox/petsc/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:760:5: error: expected expression before '/' token
>>>>>>>>> To opt-out from receiving these messages - send a request to petsc-dev at mcs.anl.gov.
