[petsc-dev] TAO convergence tests are undecipherable
Jason Sarich
sarich at mcs.anl.gov
Wed Sep 9 09:26:31 CDT 2015
Todd, can you come up with a reason why we might need to keep these fatol,
frtol tests around? I would prefer to take them out.
Jason
On Tue, Sep 8, 2015 at 9:54 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> Jason,
> Perhaps it is just documentation.
> TaoSetTolerances - Sets parameters used in TAO convergence tests
> Logically collective on Tao
> Input Parameters:
> + tao - the Tao context
> . fatol - absolute convergence tolerance
> . frtol - relative convergence tolerance
> . gatol - stop if norm of gradient is less than this
> . grtol - stop if relative norm of gradient is less than this
> - gttol - stop if norm of gradient is reduced by this factor
> Options Database Keys:
> + -tao_fatol <fatol> - Sets fatol
> . -tao_frtol <frtol> - Sets frtol
> . -tao_gatol <gatol> - Sets gatol
> . -tao_grtol <grtol> - Sets grtol
> - -tao_gttol <gttol> - Sets gttol
> Stopping Criteria:
> $ f(X) - f(X*) (estimated) <= fatol
> $ |f(X) - f(X*)| (estimated) / |f(X)| <= frtol
> $ ||g(X)|| <= gatol
> $ ||g(X)|| / |f(X)| <= grtol
> $ ||g(X)|| / ||g(X0)|| <= gttol
> How is f(x) - f(X*) (estimated) and how come the second definition has
> absolute values but the first does not?
> From below it looks like f(x) - f(X*) is estimated as gnorm*gnorm?
> } else if (gnorm2 <= fatol && cnorm <=catol) {
> ierr = PetscInfo2(tao,"Converged due to estimated f(X) - f(X*) = %g <
> %g\n",(double)gnorm2,(double)fatol);CHKERRQ(ierr);
> reason = TAO_CONVERGED_FATOL;
> } else if (f != 0 && gnorm2 / PetscAbsReal(f)<= frtol &&
> cnorm/PetscMax(cnorm0,1.0) <= crtol) {
> ierr = PetscInfo2(tao,"Converged due to estimated |f(X)-f(X*)|/f(X) =
> %g < %g\n",(double)(gnorm2/PetscAbsReal(f)),(double)frtol);CHKERRQ(ierr);
> reason = TAO_CONVERGED_FRTOL;
> It seems the next test is the same as the first I list above exact gnorm
> is not squared? Why is it worth having this duplicate test?
> } else if (gnorm<= gatol && cnorm <=catol) {
> ierr = PetscInfo2(tao,"Converged due to residual norm ||g(X)||=%g <
> %g\n",(double)gnorm,(double)gatol);CHKERRQ(ierr);
> reason = TAO_CONVERGED_GATOL;
> At a minimum the manual page should document what f(X) - f(X*)
> (estimated) means.
> Barry
> } else if ( f!=0 && PetscAbsReal(gnorm/f) <= grtol && cnorm <= crtol) {
> ierr = PetscInfo2(tao,"Converged due to residual ||g(X)||/|f(X)| =%g <
> %g\n",(double)(gnorm/f),(double)grtol);CHKERRQ(ierr);
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150909/b425b59d/attachment.html>
