[petsc-dev] Open solaris 64bit printf bug?
    Satish Balay
    balay at mcs.anl.gov
    Thu Sep  3 23:30:46 CDT 2015
Perhaps the following is the fix?
Satish
diff --git a/src/vec/vec/utils/vsection.c b/src/vec/vec/utils/vsection.c
index 4923238..444c8ac 100644
--- a/src/vec/vec/utils/vsection.c
+++ b/src/vec/vec/utils/vsection.c
@@ -22,7 +22,7 @@ PetscErrorCode PetscSectionVecView_ASCII(PetscSection s, Vec v, PetscViewer view
     if ((s->bc) && (s->bc->atlasDof[p] > 0)) {
       PetscInt b;
-      ierr = PetscViewerASCIISynchronizedPrintf(viewer, "  (%4d) dim %2d offset %3d", p+s->pStart, s->atlasDof[p], s->atlasOff[p]);CHKERRQ(ierr);
+      ierr = PetscViewerASCIISynchronizedPrintf(viewer, "  (%4D) dim %2D offset %3D", p+s->pStart, s->atlasDof[p], s->atlasOff[p]);CHKERRQ(ierr);
       for (i = s->atlasOff[p]; i < s->atlasOff[p]+s->atlasDof[p]; ++i) {
         PetscScalar v = array[i];
 #if defined(PETSC_USE_COMPLEX)
@@ -43,7 +43,7 @@ PetscErrorCode PetscSectionVecView_ASCII(PetscSection s, Vec v, PetscViewer view
       ierr = PetscViewerASCIISynchronizedPrintf(viewer, "\n");CHKERRQ(ierr);
     } else {
@@ -87,7 +87,7 @@ PetscErrorCode PetscSectionVecView(PetscSection s, Vec v, PetscViewer viewer)
     if (s->numFields) {
       ierr = PetscViewerASCIIPrintf(viewer, "%s with %d fields\n", name, s->numFields);CHKERRQ(ierr);
       for (f = 0; f < s->numFields; ++f) {
-        ierr = PetscViewerASCIIPrintf(viewer, "  field %d with %d components\n", f, s->numFieldComponents[f]);CHKERRQ(ierr);
+        ierr = PetscViewerASCIIPrintf(viewer, "  field %D with %D components\n", f, s->numFieldComponents[f]);CHKERRQ(ierr);
         ierr = PetscSectionVecView_ASCII(s->field[f], v, viewer);CHKERRQ(ierr);
     } else {
balay at n-gage:~/petsc.clone/src/dm/impls/plex/examples/tests$ make runex3_nonconforming_tensor_2
319,321c319,321
< Null vector 0 is likely null vector|| A * v[0] || = 8.64582e-17
< Null vector 1 is likely null vector|| A * v[1] || = 5.97914e-17
< Null vector 2 is likely null vector|| A * v[2] || = 7.89038e-17
> Null vector 0 is likely null vector|| A * v[0] || = 2.73185e-17
> Null vector 1 is likely null vector|| A * v[1] || = 7.80433e-17
> Null vector 2 is likely null vector|| A * v[2] || = 5.42673e-17
/home/balay/petsc.clone/src/dm/impls/plex/examples/tests
Possible problem with with runex3_nonconforming_tensor_2, diffs above
On Thu, 3 Sep 2015, Barry Smith wrote:
>   And just to annoy me I cannot get -start_in_debugger to work on that machine. Valgrind has no complaints on a Mac with the examples.
>   I've found some miss-use of PetscViewerASCIIPushSynchronized() and %d in parts of plex, I don't see how they could cause this problem but I am fixing them and will push that. Maybe we'll get lucky.
>   Barry
> > On Sep 3, 2015, at 10:06 AM, Tobin Isaac <tisaac at ices.utexas.edu> wrote:
> > Here's a partial diff from http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/03/examples_next_arch-opensolaris-misc_n-gage.log:
> >    232c232
> >    <   field 0 with 2 components
> >>  field 0 with 0 components
> >    234,242c234,242
> >    <   (   2) dim  2 offset   0 0.5 0
> >    <   (   3) dim  2 offset   2 1 0
> >    <   (   4) dim  2 offset   4 0 0.5
> >    <   (   5) dim  2 offset   6 0.5 0.5
> >    <   (   6) dim  2 offset   8 1 0.5
> >    <   (   7) dim  2 offset  10 0 1
> >    <   (   8) dim  2 offset  12 0.5 1
> >    <   (   9) dim  2 offset  14 0.5 0.25
> >    <   (  10) dim  2 offset  16 0.25 0.5
> >>  (   2) dim  0 offset   2 0.5 0
> >>  (   3) dim  0 offset   2 1 0
> >>  (   4) dim  0 offset   2 0 0.5
> >>  (   5) dim  0 offset   2 0.5 0.5
> >>  (   6) dim  0 offset   2 1 0.5
> >>  (   7) dim  0 offset   2 0 1
> >>  (   8) dim  0 offset   2 0.5 1
> >>  (   9) dim  0 offset   2 0.5 0.25
> >>  (  10) dim  0 offset   2 0.25 0.5
> > The numbers that printf is making 0 (or 2) clearly aren't, because
> > they are used to iterate over a section and display its contents.  But
> > other PetscInt's are printed fine elsewhere.  Weird.
> >  Toby
