[petsc-dev] plex error in next, new
    Barry Smith
    bsmith at mcs.anl.gov
    Fri Oct 30 14:46:52 CDT 2015
  Satish can provide more details on how you can easily run in the EXACT environment where something broke to debug it much faster.  The model is
1)  ssh petsc at login.mcs.anl.gov
2) ssh testmachine  (testmachine is always the end part of the name of the log file)
3) cd to either  /sandbox/petsc/petsc.test  or /home/petsc/petsc.test depending on the machine
4) git fetch
5) git checkout the broken branch
6) set PETSC_ARCH=arch of broken machine, this is in the name of the log filename
7) ./config/examples/${PETSC_ARCH}.py
8) build PETSc and debug away.
  If you have any trouble with this let Satish and I know. It is the intention that debugging on the test machines should be very straightforward and not require getting help from anyone or following convoluted instructions.
  Barry
> On Oct 30, 2015, at 2:15 PM, Matthew Knepley <knepley at gmail.com> wrote:
> I ran it through valgrind on my machine with no problems. Checking logs
>    Matt
> On Thu, Oct 29, 2015 at 5:09 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> <   [3] Roots referenced by my leaves, by rank
> < Symmetric gradient null space: PASS
> < Function tests pass for order 0 at tolerance 1e-10
> < Function tests pass for order 0 derivatives at tolerance 1e-10
> > [2]PETSC ERROR: #1 PetscCommDuplicate() line 178 in /usr/home/balay/petsc.clone-3/src/sys/objects/tagm.c
> > [2]PETSC ERROR: #2 PetscHeaderCreate_Private() line 60 in /usr/home/balay/petsc.clone-3/src/sys/objects/inherit.c
> > [2]PETSC ERROR: #3 PetscSFCreate() line 44 in /usr/home/balay/petsc.clone-3/src/vec/is/sf/interface/sf.c
> > [2]PETSC ERROR: #4 DMPlexDistribute() line 1562 in /usr/home/balay/petsc.clone-3/src/dm/impls/plex/plexdistribute.c
> > [2]PETSC ERROR: #5 CreateMesh() line 232 in /usr/home/balay/petsc.clone-3/src/dm/impls/plex/examples/tests/ex3.c
> > [2]PETSC ERROR: #6 main() line 911 in /usr/home/balay/petsc.clone-3/src/dm/impls/plex/examples/tests/ex3.c
> > [2]PETSC ERROR: PETSc Option Table entries:
> > [2]PETSC ERROR: -dim 3
> > [2]PETSC ERROR: -dm_plex_max_projection_height 2
> > [2]PETSC ERROR: -dm_view ascii::ASCII_INFO_DETAIL
> > [2]PETSC ERROR: -malloc_dump
> > [2]PETSC ERROR: -nox
> > [2]PETSC ERROR: -nox_warning
> > [2]PETSC ERROR: -num_comp 3
> > [2]PETSC ERROR: -petscpartitioner_type simple
> > [2]PETSC ERROR: -petscspace_order 1
> > [2]PETSC ERROR: -petscspace_poly_tensor
> > [2]PETSC ERROR: -qorder 1
> > [2]PETSC ERROR: -simplex 0
> > [2]PETSC ERROR: -test_fe_jacobian
> > [2]PETSC ERROR: -tree
> > [2]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
> > application called MPI_Abort(MPI_COMM_WORLD, 1) - process 2
> > [cli_2]: aborting job:
> > =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> > =   PID 15231 RUNNING AT wii
> > =   EXIT CODE: 1
> > =   CLEANING UP REMAINING PROCESSES
> > =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> Possible problem with with runex3_nonconforming_tensor_3, diffs above
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
