[petsc-dev] Ugly feature of __float128
Jed Brown
jed at jedbrown.org
Wed Oct 28 23:38:54 CDT 2015
Barry Smith <bsmith at mcs.anl.gov> writes:
> After wasting hours debugging I just realized that gcc __float128
> REQUIRES that numerical constants be written with a q suffix or
> first they are treated as double and then converted to __float.
Unsuffixed numeric literals are double. It's the semantic of the
language, not something they can change by adding a type. Sorry.
> I cannot understand why this is done this way. Who wants to convert a code to __float128 and have to then label all floating point numbers with a q which of course also means the code is not compilable with other compilers in double.
It's ugly, but you can put it in a macro:
#define NUM(a) a ## q
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151028/7dfb7b07/attachment.sig>
