[petsc-dev] including PETSc4py (and Tao4py) inside PETSc repository
Thu Oct 22 15:20:14 CDT 2015
   Lisandro,
    You never responded to this. I assume it was because you did not like the idea? This is not an attempt to take control of petsc4py or to take credit away from petsc4py from you. Petsc4py is your package and you will always be the one who deserves the credit.
    The problem is that mutual efficient development of very intertwined packages is difficult if they are in different respositories. For example petsc4py has been out of date with petsc master for many weeks now because it is too much effort to update the petsc4py repository each time we make some change in PETSc. Thus it becomes a burden on you to go in every once in a while and fix up petsc4py. With one repository changes would happen in both PETSc source and petsc4py source at the same time and tests would detect problems immediately.
   Thoughts?
   Barry
> On Sep 22, 2015, at 3:39 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Lisandro,
>    Now that everyone is using git and knows branches well can we move PETSc4py inside the PETSc repository as was done a couple of years ago with BuildSystem. Now when changes/additions are made to PETSc there is a slow inefficient, often forgotten manual process of bringing them over to petsc4py. If we put them all in one repository the updates happen quickly and far more efficiently, as would testing. We'll also get the ability to do bi-section.
>   I realize you want a PETSc4py release to be compatible with previous versions of PETSc; this property could still remain and we could easily have a tool that "pulls out" the petsc4py release material from the petsc repository.
>   I think once we make this change we'll wonder why we didn't do it log ago; just as when we changed BuildSystem.  Thoughts?
>   Thanks
>    Barry
