[petsc-dev] download-ml failure with perl-5.22
Jed Brown jed at jedbrown.org
Mon Oct 19 15:13:26 CDT 2015
I have updated pkg-ml with this fix.  Satish, could you roll a new tarball?
Jed Brown <jed at jedbrown.org> writes:
> My --download-ml fails with the following:
> perl ./config/generate-makeoptions.pl ./src/Makefile ML > /home/jed/petsc/mpich-optg/include/Makefile.export.ml.macros
> Makefile:754: recipe for target 'install-exec-hook' failed
> make[3]: Leaving directory '/home/jed/petsc/mpich-optg/externalpackages/ml'
> Makefile:645: recipe for target 'install-exec-am' failed
> make[2]: Leaving directory '/home/jed/petsc/mpich-optg/externalpackages/ml'
> Makefile:602: recipe for target 'install-am' failed
> make[1]: Leaving directory '/home/jed/petsc/mpich-optg/externalpackages/ml'
> Makefile:325: recipe for target 'install-recursive' failedCan't use 'defined(@array)' (Maybe you should just omit the defined()?) at ./config/generate-makeoptions.pl line 13.
> The relevant code is:
>   if( !(defined(@ARGV) && scalar(@ARGV)==2) ) {
>     die "Error, this script takes two and only two arguments (makefile_name package_name).!\n";
> Using defined() on arrays has been deprecated for ages, but was finally
> removed in perl 5.22.
> https://metacpan.org/pod/distribution/perl/pod/perldelta.pod#defined-array-and-defined-hash-are-now-fatal-errors
> I rarely touch Perl, but I think they could safely rewrite this as
>   if($#ARGV != 1) {
> Also, this file was deleted over 4 years ago in their repository.  I
> feel like we're going to become de-facto maintainers of standalone ML if
> we don't find a way to move to the version that upstream develops (which
> is now tangled in Trilinos, at least from a build perspective).
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151019/b3580ebb/attachment.sig>
