[petsc-dev] problems with shared libraries and pragmatic.py
Satish Balay
balay at mcs.anl.gov
Thu Oct 15 17:25:19 CDT 2015
On Thu, 15 Oct 2015, Jed Brown wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> But is this the only way? Why on earth should the person distributing a
> shared library be the one that needs to make a decision about whether a
> *user* of that library links using RPATH or not?
I believe thats an OSX requirement. I think its more like - the
library should be able to find itself :) [esp when its copied over or
moved arround with 'make install']
We do the same with libpetsc.dylib in config/install.py
Satish
