[petsc-dev] [Bitbucket] Pull request #375: Pass LDFLAGS down to GNUPackage externalpackages. (petsc/petsc)
Dmitry Karpeyev
dkarpeev at gmail.com
Sun Oct 11 13:06:41 CDT 2015
I'll try both. I assume these don't break all of 'next'? :-) I guess I
still don't understand why LinkerFlags includes compiler flags. Clearly,
though, LinkerFlags != LDFLAGS. Weird.
On Sun, Oct 11, 2015, 12:59 Barry Smith <bsmith at mcs.anl.gov> wrote:
> or
> args.append('LDFLAGS="'+self.removeCompilerFlags(self.getLinkerFlags())+'"')
> > On Oct 11, 2015, at 12:55 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > Perhaps the following is the fix Dmitry needs..
> > Satish
> > diff --git a/config/BuildSystem/config/package.py
> b/config/BuildSystem/config/package.py
> > index ebe3d15..4917ce5 100644
> > --- a/config/BuildSystem/config/package.py
> > +++ b/config/BuildSystem/config/package.py
> > @@ -1034,7 +1034,7 @@ class GNUPackage(Package):
> args.append('CFLAGS="'+self.removeWarningFlags(self.getCompilerFlags())+'"')
> > args.append('AR="'+self.setCompilers.AR+'"')
> > args.append('ARFLAGS="'+self.setCompilers.AR_FLAGS+'"')
> > - args.append('LDFLAGS="'+self.getLinkerFlags()+'"')
> > + args.append('LDFLAGS="'+self.setCompilers.LDFLAGS+'"')
> > self.popLanguage()
> > if hasattr(self.compilers, 'CXX'):
> > self.pushLanguage('Cxx')
> > On Sun, 11 Oct 2015, Satish Balay wrote:
> >> not sure about autoconf - but we do:
> >> c-compile-only: CPPFLAGS CFLAGS COPTFLAGS
> >> clinker: LDFLAGS? CFLAGS COPTFLAGS () LIB
> >> Perhaps configure should somehow preserve LDFLAGS option to configure
> >> - and make it accessiable to package.py somehow.
> >> Satish
> >> On Sun, 11 Oct 2015, Barry Smith wrote:
> >>> Matt,
> >>> In c.py Linker.getFlags() is defined as
> >>> def getFlags(self):
> >>> '''Returns a string with the flags specified for running this
> processor.'''
> >>> if not hasattr(self, '_flags'):
> >>> flagsName = self.flagsName[:]
> >>> if self.name == self.compiler.name:
> >>> flagsName.extend(self.compiler.flagsName)
> >>> if hasattr(self, 'configCompilers'):
> >>> flags = ' '.join([getattr(self.configCompilers, name) for name
> in flagsName])
> >>> else:
> >>> flags = ' '.join([self.argDB[name] for name in flagsName])
> >>> return flags
> >>> in other words if the name of the linker is the same as the name of
> the compiler it sticks all the compiler flags on as linker flags. WTF?
> Compiler flags are compiler flags, not linker flags; it is amazing this
> doesn't do more damage.
> >>> How to fix this? Do any of the compiler flags need to be made into
> linker flags?
> >>> Barry
> >>>> On Oct 9, 2015, at 1:48 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> >>>>> LDFLAGS="-Wall -Wwrite-strings -Wno-strict-aliasing
> -Wno-unknown-pragmas -Qunused-arguments -g3"
> >>>> Wrt clang+gfortran - the trigger is: -Qunused-arguments [which is a
> >>>> clang flag - that gets passed to flinker aswell?]
> >>>> balay at es^~/junk $ gfortran -Qunused-arguments cmd.f
> >>>> gfortran: error: unrecognized command line option ‘-Qunused-arguments’
> >>>> Satish
> >>>> On Fri, 9 Oct 2015, Barry Smith wrote:
> >>>>> Well that's what the tests are for, to find such problems.
> >>>>> Perhaps it should not be in GNUPackage but only in the individual
> xxx.py packages that require it? But how do we know which packages need it
> and even then will be compatible on all systems.
> >>>>> Dmitry, please send the exact error that you got that inspired you
> to add this to the Gnumake package.
> >>>>> Barry
> >>>>>> On Oct 9, 2015, at 1:24 PM, Satish Balay <
> pullrequests-reply at bitbucket.org> wrote:
> >>>>>> Satish Balay commented on pull request #375:
> >>>>>> Nightlybuilds broke due to this change [primarily --download-mpich
> - esp with clang+gfortran - and other combinations]
> >>>>>> View this pull request or add a comment by replying to this email.
> >>>>>> Unsubscribe from pull request emails for this repository.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151011/af21ea90/attachment.html>
