[petsc-dev] [Bitbucket] Pull request #375: Pass LDFLAGS down to GNUPackage externalpackages. (petsc/petsc)
    Satish Balay
    balay at mcs.anl.gov
    Sun Oct 11 12:38:45 CDT 2015
not sure about autoconf  - but we do:
c-compile-only: CPPFLAGS CFLAGS COPTFLAGS
clinker:      LDFLAGS? CFLAGS COPTFLAGS () LIB
Perhaps configure should somehow preserve LDFLAGS option to configure
- and make it accessiable to package.py somehow.
Satish
On Sun, 11 Oct 2015, Barry Smith wrote:
>   Matt,
>   In c.py Linker.getFlags() is defined as
>     def getFlags(self):
>     '''Returns a string with the flags specified for running this processor.'''
>     if not hasattr(self, '_flags'):
>       flagsName = self.flagsName[:]
>       if self.name == self.compiler.name:
>         flagsName.extend(self.compiler.flagsName)
>       if hasattr(self, 'configCompilers'):
>         flags = ' '.join([getattr(self.configCompilers, name) for name in flagsName])
>       else:
>         flags = ' '.join([self.argDB[name] for name in flagsName])
>       return flags
> in other words if the name of the linker is the same as the name of the compiler it sticks all the compiler flags on as linker flags. WTF? Compiler flags are compiler flags, not linker flags; it is amazing this doesn't do more damage.
>  How to fix this? Do any of the compiler flags need to be made into linker flags?
> Barry
> > On Oct 9, 2015, at 1:48 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> >> LDFLAGS="-Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -Qunused-arguments -g3"
> > Wrt clang+gfortran - the trigger is: -Qunused-arguments [which is a
> > clang flag - that gets passed to flinker aswell?]
> > balay at es^~/junk $ gfortran -Qunused-arguments cmd.f
> > gfortran: error: unrecognized command line option ‘-Qunused-arguments’
> > Satish
> > On Fri, 9 Oct 2015, Barry Smith wrote:
> >>   Well that's what the tests are for, to find such problems.
> >>   Perhaps it should not be in GNUPackage but only in the individual xxx.py packages that require it? But how do we know which packages need it and even then will be compatible on all systems.
> >>   Dmitry, please send the exact error that you got that inspired you to add this to the Gnumake package.
> >>  Barry
> >>> On Oct 9, 2015, at 1:24 PM, Satish Balay <pullrequests-reply at bitbucket.org> wrote:
> >>> Satish Balay commented on pull request #375:
> >>> Nightlybuilds broke due to this change [primarily --download-mpich - esp with clang+gfortran - and other combinations]
> >>> View this pull request or add a comment by replying to this email.
> >>> Unsubscribe from pull request emails for this repository.
