[petsc-dev] Slow ViennaCL performance on KSP ex12
Mani Chandra
mc0710 at gmail.com
Sat Oct 10 15:08:42 CDT 2015
Following http://www.mcs.anl.gov/petsc/petsc-20/conference/Rupp_K.pdf (page
16), I ran KSP ex12 for two cases:
1) time ./ex12 -m 100 -n 100 -log_summary > log_summary_no_viennacl
real 0m0.213s
user 0m0.206s
sys 0m0.004s
2) ./ex12 -m 100 -n 100 -vec_type viennacl -mat_type aijviennacl
-log_summary > log_summary_with_viennacl
real 0m20.296s
user 0m46.025s
sys 0m1.435s
The runs have been performed on a CPU : AMD A10-5800K, with OpenCL from
AMD-APP-SDK-v3.0.
Attached are:
1) configure.log for the petsc build
2) log summary without viennacl
3) log summary with viennacl
4) OpenCL info for the system on which the runs were performed
Perhaps the reason for the slow performance are superfluous copies being
performed, which need not occur when running ViennaCL on the CPU. Looking
at
http://www.mcs.anl.gov/petsc/petsc-dev/src/vec/vec/impls/seq/seqviennacl/vecviennacl.cxx
/* Copies a vector from the CPU to the GPU unless we already have an
up-to-date copy on the GPU */
PetscErrorCode VecViennaCLCopyToGPU(Vec v)
PetscErrorCode ierr;
PetscFunctionBegin;
ierr = VecViennaCLAllocateCheck(v);CHKERRQ(ierr);
if (v->map->n > 0) {
if (v->valid_GPU_array == PETSC_VIENNACL_CPU) {
ierr = PetscLogEventBegin(VEC_ViennaCLCopyToGPU,v,0,0,0);CHKERRQ(ierr);
try {
ViennaCLVector *vec = ((Vec_ViennaCL*)v->spptr)->GPUarray;
viennacl::fast_copy(*(PetscScalar**)v->data,
*(PetscScalar**)v->data + v->map->n, vec->begin());
ViennaCLWaitForGPU();
} catch(std::exception const & ex) {
SETERRQ1(PETSC_COMM_SELF,PETSC_ERR_LIB,"ViennaCL error: %s", ex.what());
ierr = PetscLogEventEnd(VEC_ViennaCLCopyToGPU,v,0,0,0);CHKERRQ(ierr);
v->valid_GPU_array = PETSC_VIENNACL_BOTH;
PetscFunctionReturn(0);
When running ViennaCL with OpenCL on the CPU, the above function should
maybe be modified?
Cheers,
Mani
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151010/059d79f6/attachment.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151010/059d79f6/attachment.bin>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151010/059d79f6/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151010/059d79f6/attachment-0001.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151010/059d79f6/attachment-0002.obj>
