[petsc-dev] Bug in MatShift_MPIAIJ ?
Eric Chamberland
Eric.Chamberland at giref.ulaval.ca
Thu Oct 8 13:45:10 CDT 2015
Ok,
if I comment the following lines (added in 3.6.2), it works:
PetscErrorCode MatShift_MPIAIJ(Mat Y,PetscScalar a)
PetscErrorCode ierr;
Mat_MPIAIJ *maij = (Mat_MPIAIJ*)Y->data;
Mat_SeqAIJ *aij = (Mat_SeqAIJ*)maij->A->data;
PetscFunctionBegin;
if (!Y->preallocated) {
ierr = MatMPIAIJSetPreallocation(Y,1,NULL,0,NULL);CHKERRQ(ierr);
} /*else if (!aij->nz) {
ierr = MatSeqAIJSetPreallocation(maij->A,1,NULL);CHKERRQ(ierr);
ierr = MatShift_Basic(Y,a);CHKERRQ(ierr);
PetscFunctionReturn(0);
Eric
On 08/10/15 09:45 AM, Eric Chamberland wrote:
> Hi!
> hint: For petsc 3.6.1, if I apply the patches that Patrick gave (in the
> head of this thread), it all works correctly,
> Eric
> On 07/10/15 10:11 PM, Eric Chamberland wrote:
>> Hi Jed,
>>> If I recall correctly, that patch is only checking for incorrect use by
>>> ensuring that the flags are set collectively. If your code is correct
>>> then it doesn't affect you and if your code is incorrect, it will error
>>> now where as it would behave incorrectly before. The implementation was
>>> done by changing some enum values, which is why it breaks the ABI.
>>> As Satish says, you can apply the patch and see if your code errors.
>>> If your example is simple, you can send it along so we can debug and add
>>> it to the test suite.
>> ok, after applying the patch, the code still error at the same place.
>> The fact is that doing the very same MatShift with petsc 3.5.3 was
>> working correctly... in fact it is now hanging into one of our test
>> from our test suite...
>> I will have to dig further into this...
>> to be continued...
>> Eric
> Hi!
