[petsc-dev] Manual figures are messed up
    Stefano Zampini
    stefano.zampini at gmail.com
    Thu Oct  8 13:07:51 CDT 2015
It works fine on my workstation with the current tex file.
\begin{verbatim} is defined as a token at the beginning of the script. For
the '}' match, maybe we can define a separate flag if begin{verbatim} is
active and turn off the check on '}'.
Stefano
Il 08/ott/2015 08:50 PM, "Barry Smith" <bsmith at mcs.anl.gov> ha scritto:
>    I can't image this would work because \\begin{verbatim} is not a token.
> Plus if decrease for each } you will exit the verbatim "safe" zone as soon
> as you hit a }
>   Barry
> > On Oct 8, 2015, at 9:54 AM, Stefano Zampini <stefano.zampini at gmail.com>
> wrote:
> > What about the patch in attachment?
> > 2015-10-08 1:54 GMT+03:00 Barry Smith <bsmith at mcs.anl.gov>:
> > > On Sep 30, 2015, at 7:46 AM, Stefano Zampini <
> stefano.zampini at gmail.com> wrote:
> > > I just noticed that Figures 19 and 20 in the manual (current release
> and master) are messed up. The htmlmap process seems not to work properly.
> > The tool /bin/maint/mapnameslatex.py is what looks through the tokens in
> the .tex files and replaces PETSc functions etc with an href. Unfortunately
> it is simple minded. It should turn off replacement when it detects a
> \begin{verbatim} and turn it back on when it hits the \end{verbatim} here
> is the entire engine
> >     while 1:
> >         token = lex.token()       # Get a token
> >         if not token: break        # No more tokens
> >         if token.type == 'NEWLINE':
> >             print text
> >             text = ''
> >         else:
> >             # \href cannot be used in many places in Latex
> >             if token.value in
> ['\\href{','\\findex{','\\sindex{','\\subsection{','\\chapter{','\\section{','\\caption{','\\trl{']:
> >                 bracket = bracket + 1;
> >             if bracket == 0:
> >                 value = token.value
> >                 if mappedstring.has_key(value):
> >                     mvalue = mappedstring[value].replace('_','\\_')
> >                     value = '\\href{'+'
> http://www.mcs.anl.gov/petsc/petsc-'+version+'/docs/'+mappedlink[value]+'}{'+mvalue+'
> }\\findex{'+value+'}'
> >             else:
> >                 value = token.value
> >             if token.value[0] == '}' and bracket:
> >                 bracket = bracket - 1;
> >             text = text+value
> > You want to take a crack at fixing it? Because I don't really feel like
> it :-(
> >   Barry
> > > Stefano
> > Stefano
> > <patch_manual>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151008/be5e213e/attachment.html>
