[petsc-dev] Manual figures are messed up
    Stefano Zampini
    stefano.zampini at gmail.com
    Thu Oct  8 09:54:59 CDT 2015
What about the patch in attachment?
2015-10-08 1:54 GMT+03:00 Barry Smith <bsmith at mcs.anl.gov>:
> > On Sep 30, 2015, at 7:46 AM, Stefano Zampini <stefano.zampini at gmail.com>
> wrote:
> > I just noticed that Figures 19 and 20 in the manual (current release and
> master) are messed up. The htmlmap process seems not to work properly.
> The tool /bin/maint/mapnameslatex.py is what looks through the tokens in
> the .tex files and replaces PETSc functions etc with an href. Unfortunately
> it is simple minded. It should turn off replacement when it detects a
> \begin{verbatim} and turn it back on when it hits the \end{verbatim} here
> is the entire engine
>     while 1:
>         token = lex.token()       # Get a token
>         if not token: break        # No more tokens
>         if token.type == 'NEWLINE':
>             print text
>             text = ''
>         else:
>             # \href cannot be used in many places in Latex
>             if token.value in
> ['\\href{','\\findex{','\\sindex{','\\subsection{','\\chapter{','\\section{','\\caption{','\\trl{']:
>                 bracket = bracket + 1;
>             if bracket == 0:
>                 value = token.value
>                 if mappedstring.has_key(value):
>                     mvalue = mappedstring[value].replace('_','\\_')
>                     value = '\\href{'+'
> http://www.mcs.anl.gov/petsc/petsc-'+version+'/docs/'+mappedlink[value]+'}{'+mvalue+'
> }\\findex{'+value+'}'
>             else:
>                 value = token.value
>             if token.value[0] == '}' and bracket:
>                 bracket = bracket - 1;
>             text = text+value
> You want to take a crack at fixing it? Because I don't really feel like it
>   Barry
> > Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151008/9f57d4b9/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151008/9f57d4b9/attachment.obj>
