[petsc-dev] Mac OS X El Capitan does not propagate DYLD_LIBRARY_PATH from parent process
Jed Brown jed at jedbrown.org
Wed Oct 7 17:08:19 CDT 2015
Satish Balay <balay at mcs.anl.gov> writes:
> On Wed, 7 Oct 2015, Jed Brown wrote:
>> Are those executables?  If the behavior different if you copy them to
>> HOME and/or rename them?
> yes.
Thanks.  This does suck for testing before install, because the behavior
can be totally different depend on where you install to.  But at least
we understand the semantics now (and the discussion at
developer.apple.com is the blind leading the blind).
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151007/6d562baa/attachment.sig>
