[petsc-dev] Mac OS X El Capitan does not propagate DYLD_LIBRARY_PATH from parent process
Jed Brown
jed at jedbrown.org
Wed Oct 7 16:36:36 CDT 2015
Satish Balay <balay at mcs.anl.gov> writes:
> So 'env' and 'printenv' cannont find DYLD_LIBRARY_PATH? - but 'echo' can?
$DYLD_LIBRARY_PATH is expanded by the calling shell, so this doesn't say
anything about "echo". Also,
$ type echo
echo is a shell builtin
$ type env
env is /usr/bin/env
$ type printenv
printenv is /usr/bin/printenv
> Trying out code from http://stackoverflow.com/questions/2085302/printing-all-environment-variables-in-c-c
> balay at imav^~/junk $ cat env2.c
> #include <stdio.h>
> int main(int argc, char **argv, char** envp)
> char** env;
> for (env = envp; *env != 0; env++)
> char* thisEnv = *env;
> printf("%s\n", thisEnv);
> return(0);
> balay at imav^~/junk $ gcc env2.c
> alay at imav^~/junk $ ./a.out |grep DYLD
> DYLD_LIBRARY_PATH=foobar
> This works - but not env, printenv?
Are those executables? If the behavior different if you copy them to
HOME and/or rename them?
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151007/e12a1e4c/attachment.sig>
