[petsc-dev] Support for projections in petsc solvers
Barry Smith
bsmith at mcs.anl.gov
Fri Oct 2 13:16:39 CDT 2015
> On Oct 2, 2015, at 2:23 AM, Alejandro Cosimo <alecosimo at gmail.com> wrote:
> Thanks Matt and Barry for the answer. Regarding the preconditioning. I have three steps which act successively on the residual, projection (w=P^T*r), preconditioning (z=M^{-1}*w) and re-projection (y=P*z). But all those steps can be interpreted as a single preconditioning step, mainly the application of P*M^{-1}*P^T on the residual. I can implement that inside my PCApply.
> Regarding the use of a new convergence test routine for checking on P^T*r for convergence: I think it could work, although it would be good to manage explicitly the projections inside the solver.
Why would it be "good to manage the projections inside the solver"?
Barry
> Regards,
> Alejandro
> 2015-10-01 23:16 GMT+02:00 Barry Smith <bsmith at mcs.anl.gov>:
> Do you mean application of the precondition is P*M^{-1}*P^T ApplyPC P*M^{-1}*P^T or something else?
> If so then PCCOMPOSITE is not for this purpose in any way. You just need to do all three things inside your PCApply.
> > On Oct 1, 2015, at 4:38 AM, Alejandro Cosimo <alecosimo at gmail.com> wrote:
> > Hello everybody,
> > I'm interested in implementing FETI-1. Regardless of the iterative solver used for solving the interface problem, before applying the preconditioner it is required to project the residual and after applying the preconditioner to the projected residual to re-project again. It could seem that PCCOMPOSITE could be used in this case, performing the operation P*M^{-1}*P^T at once over the residual. However, this is not useful for the general case in FETI-1 because the convergence of the iterative solver must be checked with the projected residual, that is P^T*r, or in same cases with M^{-1}*P^T*r, but not with P*M^{-1}*P^T*r. That is why I would need support for projection and reprojection phases in petsc solvers.
> As Matt said if you are checking on something like P^T*r for convergence then you do that with a new convergence test routine.
> BTW: Maybe you could use the source of KSPCreate_FCG() as a starting point for a CG implementation that keeps a complete history.
> Barry
> > Right now there is no support for that. So, my question: for implementing the support of the projection and reprojection phases in petsc I would introduce the functions ApplyProjection and ApplyReProjection to the petsc implementation in the same way that, for example, ApplyPC is supported. What do you think about this? Would you proceed like this?
> > After implementing the support for ApplyProjection and ApplyReProjection, I would incorporate the behavior to one of the petsc iterative solvers. For that I would adopt the GMRES solver because it prevents me from implementing the full re-orthogonalization that is required when CG is adopted as iterative solver for FETI-1 (something which is not implemented in petsc CG). In that case, do you recommend me to define a new GMRES in petsc, or to modify the already exiting GMRES implementation by introducing the option of performing the phases of projection and reprojection?
> > Regards,
> > Alejandro
