[petsc-dev] Clang configure
    Matthew Knepley
    knepley at gmail.com
    Fri Oct  2 07:02:55 CDT 2015
On Thu, Oct 1, 2015 at 12:08 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Oct 1, 2015 at 12:06 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> On Thu, 1 Oct 2015, Matthew Knepley wrote:
>> > master *:~$ clang --version
>> > Apple LLVM version 6.0 (clang-600.0.57) (based on LLVM 3.5svn)
>> > Target: x86_64-apple-darwin13.4.0
>> > Thread model: posix
>> This is the default Mac compiler - and we din't have issues with it
>> before.
> We did actually, but they were silently ignored and configured worked
> around it. Toby's
> new code dies if -fPIC is rejected.
That did not work since the options are processed after the shared linker
check.
   Matt
>   Matt
>> [I would have thought Barry would have seen this issue]
>> And I see on the Mac - I have access to - the version is:
>> balay at imav^~ $ sudo clang --version
>> Apple LLVM version 7.0.0 (clang-700.0.72)
>> Target: x86_64-apple-darwin14.5.0
>> Thread model: posix
>> Will try a build and see how it goes..
>> Satish
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151002/c959f0ec/attachment.html>
