[petsc-dev] did I mess up master?
Jed Brown
jed at jedbrown.org
Tue Mar 31 16:20:42 CDT 2015
Mark Adams <mfadams at lbl.gov> writes:
> I see, I forgot to pull.
> These were trivial changes: changed a variable name (that is a key word)
> and fixed a test that did not compile anymore so I did it directly on
> master.
The commit messages says "demonstrates a bug". Is there a bug? What is
it?
As for non-fast-forward merges, Junio just published a blog post
explaining the rationale for maintaining first-parent history and the
way to gracefully retry in case of racy integration. (His advice is the
same as ours.) He also mentions discussion of a "git rebase
--first-parent" feature that would make this process easier.
http://git-blame.blogspot.com/2015/03/fun-with-non-fast-forward.html
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150331/2b780ab2/attachment.sig>
