[petsc-dev] did I mess up master?
Jed Brown
jed at jedbrown.org
Mon Mar 30 10:49:54 CDT 2015
Satish Balay <balay at mcs.anl.gov> writes:
> You mean 'origin/master' was ahead of 'origin' by 44 commits?
> The following looks ok to me. [presumably 9780fa96a767300e577882a0af3393de3467f0b4
> was where 'master' was at - when you tried to push..]
> $ git log 9780fa96a767300e577882a0af3393de3467f0b4..23524bc85f88d7c2c867e276c52fc9d9816c7ba0
> commit 23524bc85f88d7c2c867e276c52fc9d9816c7ba0
> Merge: a45e4fd 9780fa9
> Author: Mark Adams <mfadams at lbl.gov>
> Date: Sun Mar 29 07:56:12 2015 -0700
> Merge branch 'master' of https://bitbucket.org/petsc/petsc
This is a merge from upstream. You're supposed to pull first, then
merge your branch.
https://bitbucket.org/petsc/petsc/wiki/developer-instructions-git#markdown-header-racy-integration
What you did makes it harder to interpret the history and more difficult
to summarize changes using --first-parent. It's not a catastrophe, not
ideal either.
> commit a45e4fd2de284282fd0ffec31edee9d059d8ad33
> Date: Sun Mar 29 07:55:57 2015 -0700
> fixed example to compile - demonstrates a bug
What bug? Is it an open bug? Is there a failing test? How can I
possibly find out? (This commit message could be better.)
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150330/a2a2cd3a/attachment.sig>
