[petsc-dev] More on FV overlap cells and Fortran
Matthew Knepley
knepley at gmail.com
Fri Mar 27 14:03:37 CDT 2015
On Fri, Mar 13, 2015 at 2:09 PM, John O'Sullivan <
jp.osullivan at auckland.ac.nz> wrote:
> Hi Matt,
> I think we'd prefer a Fortran wrapper for
> DMPlexGetGlobalOffset_Internal(). We've got our heads around offsets now
> and are happy working with them.
I apologize for taking so long. I got caught up in the SIAM Meeting. I have
pushed
PetscErrorCode DMPlexGetPointGlobalField(DM dm, PetscInt point, PetscInt
field, PetscInt *start, PetscInt *end)
to next. This corresponds with the public interface naming scheme Jed
started.
> In a relate query, when we're setting up a new vector with a different dof
> then we follow the approach you use in plexgeometry.c (see example code
> snippet below). But I don't understand why when we run this in parallel we
> DON'T need to check if the cell is off-process before calling
> PetscSectionSetDof. In fact when I did check (using the ghost label
> approach) it then gave the error: "Global dof 1 for point 1 is not the
> unconstrained 0" (see full error log below)?
I am not sure you want to exclude off-process cells, since then you cannot
communicate ghost results. The
error here comes from disagreement between two procs over what dofs live in
a cell. If you want cells that
do not communicate, you should use a different PetscSF.
Matt
> Thanks!
> call DMPlexGetHeightStratum(dm, 0, start_cell, end_cell, ierr);
> CHKERRQ(ierr)
> call DMPlexGetHybridBounds(dm, end_interior_cell, &
> PETSC_NULL_INTEGER, PETSC_NULL_INTEGER, PETSC_NULL_INTEGER,
> ierr); CHKERRQ(ierr)
> call DMClone(dm, dmRocks, ierr); CHKERRQ(ierr)
> call PetscSectionCreate(PETSC_COMM_WORLD, rocks_section, ierr);
> CHKERRQ(ierr)
> call PetscSectionSetChart(rocks_section, start_cell,
> end_interior_cell, ierr); CHKERRQ(ierr)
> do c = start_cell, end_interior_cell-1
> ! Want a new vector with 4 dofs
> ! Doesn't work if we exclude cells that are off-process
> call PetscSectionSetDof(rocks_section, c, 4, ierr); CHKERRQ(ierr)
> end do
> call PetscSectionSetUp(rocks_section, ierr); CHKERRQ(ierr)
> call DMSetDefaultSection(dmRocks, rocks_section, ierr); CHKERRQ(ierr)
> call DMCreateGlobalVector(dmRocks, rockproperties, ierr); CHKERRQ(ierr)
> The full error log if we exclude off-process cells during
> PetscSectionSetDof:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Invalid argument
> [0]PETSC ERROR: Global dof 1 for point 1 is not the unconstrained 0
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: Invalid argument
> [1]PETSC ERROR: Global dof 1 for point 2 is not the unconstrained 0
> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [1]PETSC ERROR: Petsc Development GIT revision: v3.5.3-2966-g3546a49 GIT
> Date: 2015-03-12 10:43:22 -0500
> [1]PETSC ERROR: darcy on a arch-darwin-c-debug named
> Johns-MacBook-Air.local by jposunz Sat Mar 14 08:07:25 2015
> [1]PETSC ERROR: Configure options --download-fblaslapack --useThreads=0
> --download-triangle --download-netcdf --download-exodusii --download-hdf5
> --download-ptscotch --download-chaco
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> [0]PETSC ERROR: Petsc Development GIT revision: v3.5.3-2966-g3546a49 GIT
> [0]PETSC ERROR: [1]PETSC ERROR: #1 PetscSectionCreateGlobalSection() line
> 1010 in /Users/jposunz/projects/src/petsc/src/vec/is/utils/vsectionis.c
> [1]PETSC ERROR: #2 DMGetDefaultGlobalSection() line 3269 in
> /Users/jposunz/projects/src/petsc/src/dm/interface/dm.c
> [1]PETSC ERROR: #3 DMCreateGlobalVector_Section_Private() line 13 in
> /Users/jposunz/projects/src/petsc/src/dm/interface/dmi.c
> [1]PETSC ERROR: #4 DMCreateGlobalVector_Plex() line 1170 in
> /Users/jposunz/projects/src/petsc/src/dm/impls/plex/plexcreate.c
> [1]PETSC ERROR: #5 DMCreateGlobalVector() line 698 in
> darcy on a arch-darwin-c-debug named Johns-MacBook-Air.local by jposunz
> [0]PETSC ERROR: Configure options --download-fblaslapack --useThreads=0
> [0]PETSC ERROR: #1 PetscSectionCreateGlobalSection() line 1010 in
> [0]PETSC ERROR: #2 DMGetDefaultGlobalSection() line 3269 in
> [0]PETSC ERROR: #3 DMCreateGlobalVector_Section_Private() line 13 in
> [0]PETSC ERROR: #4 DMCreateGlobalVector_Plex() line 1170 in
> [0]PETSC ERROR: #5 DMCreateGlobalVector() line 698 in
> MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
> with errorcode 62.
> Dr John O'Sullivan
> Lecturer
> Department of Engineering Science
> University of Auckland, New Zealand
> email: jp.osullivan at auckland.ac.nz <https://lists.mcs.anl.gov/mailman/listinfo/petsc-dev>
> tel: +64 (0)9 923 85353
> *From:* Matthew Knepley [knepley at gmail.com]
> *Sent:* Friday, 13 March 2015 11:57 p.m.
> *To:* John O'Sullivan
> *Cc:* petsc-dev at mcs.anl.gov
> *Subject:* Re: More on FV overlap cells and Fortran
> On Fri, Mar 13, 2015 at 4:56 AM, John O'Sullivan <
>> Hi Matt,
>> We're getting there with our parallel Fortran FV code. But here's another
>> question about the best way to do things. Another simpleTest2 code is
>> attached to demonstrate the question and below is a copy of the relevant
>> part:
>> <petsc-dev at mcs.anl.gov>! We worked out its important not to write to
>> the parts of arrays that correspond to overlap cells.
>> ! Following ex11 it would be done something like this using C:
>> ! ierr = DMPlexPointGlobalRef(dm,c,x,&xc);CHKERRQ(ierr);
>> ! if (xc) {ierr =
>> (*mod->solution)(mod,0.0,cg->centroid,xc,mod->solutionctx);CHKERRQ(ierr);}
>> ! And according to the documentation on DMPlexPointGlobalRef xc would be
>> returned as null for
>> ! the overlap blocks that don't belong to the processor
>> ! We can achieve the same using the ghost labels on the overlap cells but
>> is this a good
>> ! idea? We'd prefer to follow the standard approach ie in ex11 but I
>> don't think there's a
>> ! clean way to do this in fortran as we can't pass pointers to
>> structures...
>> ! Could it be done with DMPlexPointGlobalRef? If so, any ideas?
> I can do two things:
> a) Make a Fortran version of DMPlexPointGlobalRef(), which returns an
> F90 array of size dof
> or
> b) Make a Fortran wrapper for DMPlexGetGlobalOffset_Internal(), which
> returns start/end, and
> start < 0 if its off-process
> Tell me what you think is better. Also, you can see here that we are
> experimenting with different
> interfaces. Jed likes getting a pointer back. I like getting offsets back.
> Thanks,
> Matt
>> ! ??? call DMPlexPointGlobalRef(dm, c, localx, someref)???
>> call DMLabelGetValue(label, c, ghost, ierr); CHKERRQ(ierr)
>> if (ghost < 0) then
>> call PetscSectionGetOffset(solution_section, c, cell_offset,
>> cell_offset = cell_offset + 1
>> localx(cell_offset) = 100.0
>> end if
>> end do
>> Cheers!
>> John
>> Dr John O'Sullivan
>> Lecturer
>> *From:* Matthew Knepley [mailto:knepley at gmail.com]
>>> *Sent:* Friday, 13 March 2015 4:44 a.m.
>>> *Subject:* Re: Simple Test example not working in parallel for
>>> DMPlex/FV/overlap/ghost cells...
>>> On Thu, Mar 12, 2015 at 4:19 AM, John O'Sullivan <
>>> Hi Matt,
>>> Attached is a simple test program where I'm loading the
>>> simpleblock-100.exo and trying to set up a grid with closed boundaries on
>>> all the outer faces.
>>> Just so I understand what you want. You do not want any ghost cells made
>>> around the outer boundary. What you have will do that.
>>> We'd like to do it this way so we can use the same sort of
>>> architecture as in PetscFVM to skip ghost faces when calculating fluxes
>>> (like you suggested in your response yesterday)
>>> Note that now, it will also mark the outer boundary faces as ghosts
>>> because they have no partner cell.
>>> It works fine on a single processor but when we run it on 2 processors
>>> there's an indexing error when trying to create a matrix. There's obviously
>>> something wrong with the way we're setting up the dm but I don't know what
>>> it is? Or perrhaps we're not allowed to use DMPlexConstructGhostCells in
>>> this way? Also I was surprised by the values given for end_interior_cell on
>>> each processor as it seems to include the overlap cells which is not what I
>>> expected?
>>> This is a bug in my latest preallocation push. Thanks for finding it. I
>>> pushed a fix for this, and for many Fortran things
>>> to next. I am including my modified source so that everything is
>>> deallocated correctly (run with -malloc_test).
>>> It seems to work for me now. Let me know if you have problems.
>>> Thanks,
>>> Matt
>>> One last thing, the FORTRAN interface for DMPlexCreateLabel was
>>> missing so I added it into zplexlabel.c which works fine but I'm not sure
>>> if this was the right way to do it. My version is attached.
>>> The full output from the program for two processors is below.
>>> Cheers
>>> John
>>> (ps Is there a way to make DMView output the Labels information for all
>>> processors?)
>>> $ mpirun -n 2 simpleTest2
>>> DM Object:Parallel Mesh 2 MPI processes
>>> type: plex
>>> Parallel Mesh in 3 dimensions:
>>> 0-cells: 12 16
>>> 1-cells: 20 28
>>> 2-cells: 11 16
>>> 3-cells: 2 3
>>> Labels:
>>> ClosedBoundaries: 0 strata of sizes ()
>>> Face Sets: 3 strata of sizes (2, 2, 5)
>>> Cell Sets: 1 strata of sizes (2)
>>> depth: 4 strata of sizes (12, 20, 11, 2)
>>> DM Object: 2 MPI processes
>>> type: plex
>>> DM_0x7f91c1d27ff0_0 in 3 dimensions:
>>> 0-cells: 12 16
>>> 1-cells: 20 28
>>> 2-cells: 11 16
>>> 3-cells: 2 (0) 3 (0)
>>> Labels:
>>> ghost: 2 strata of sizes (1, 10)
>>> vtk: 1 strata of sizes (1)
>>> 0 3 3 19 35
>>> 0 2 2 14 25
>>> [1]PETSC ERROR: Argument out of range
>>> [1]PETSC ERROR: Section point -1 should be in [1, 3)
>>> [0]PETSC ERROR: Argument out of range
>>> [0]PETSC ERROR: Section point -3 should be in [0, 1)
>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.5.3-2945-g6900bc9
>>> GIT Date: 2015-03-10 18:15:26 -0500
>>> [0]PETSC ERROR: simpleTest2 on a arch-darwin-c-debug named
>>> Johns-MacBook-Air.local by jposunz Thu Mar 12 22:01:26 2015
>>> [0]PETSC ERROR: #1 PetscSectionGetDof() line 499 in
>>> [0]PETSC ERROR: #2 DMPlexUpdateAllocation_Static() line 609 in
>>> /Users/jposunz/projects/src/petsc/src/dm/impls/plex/plexpreallocate.c
>>> [0]PETSC ERROR: #3 DMPlexPreallocateOperator() line 763 in
>>> [0]PETSC ERROR: #4 DMCreateMatrix_Plex() line 746 in
>>> /Users/jposunz/projects/src/petsc/src/dm/impls/plex/plex.c
>>> [0]PETSC ERROR: [1]PETSC ERROR: See
>>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>> shooting.
>>> [1]PETSC ERROR: Petsc Development GIT revision: v3.5.3-2945-g6900bc9
>>> [1]PETSC ERROR: simpleTest2 on a arch-darwin-c-debug named
>>> #5 DMCreateMatrix() line 958 in
>>> [1]PETSC ERROR: #1 PetscSectionGetDof() line 499 in
>>> [1]PETSC ERROR: #2 DMPlexUpdateAllocation_Static() line 609 in
>>> [1]PETSC ERROR: #3 DMPlexPreallocateOperator() line 763 in
>>> [1]PETSC ERROR: #4 DMCreateMatrix_Plex() line 746 in
>>> [1]PETSC ERROR: #5 DMCreateMatrix() line 958 in
>>> with errorcode 63.
>>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>>> You may or may not see output from other processes, depending on
>>> exactly when Open MPI kills them.
>>> Dr John O'Sullivan
>>> Lecturer
>>> *Sent:* Thursday, 12 March 2015 3:06 a.m.
>>> *Subject:* Re: [petsc-dev] DMPlex, Finite Volume, overlap and ghost
>>> cells...
>>> On Wed, Mar 11, 2015 at 3:34 AM, John O'Sullivan <
>>> Hi all,
>>> I've managed to get myself very confused about how to use DMPlex
>>> correctly for a distributed Finite Volume grid...
>>> My understanding was that along partition boundaries the ghost cells are
>>> used store cell information from neighbouring partitions so that the fluxes
>>> can be calculated.
>>> Though debugging through ex11 it seems like overlap is set equal to 1?
>>> I'm solving a simple pressure-diffusion equation on a 1D column (from an
>>> exo grid) which works fine on a single processor but not in parallel. I'm
>>> certainly not setting things up right or labeling correctly...
>>> Could someone please explain the most appropriate way to set up and
>>> label the DM, whether the overlap should be 0 or 1 and whether ghost cells
>>> should be placed on internal partition boundaries.
>>> Yes, for FV the partition overlap should be 1, as it is in ex11. This
>>> means that when the partition happens, we will
>>> put a layer of cells on the other side of partition boundaries,
>>> When DMPlexConstructGhostCells() is called, it will put ghost cells on
>>> the other side of the true boundary. Both
>>> kinds of cells will be separated from interior cells by the
>>> DMPlexGetHybridBounds(&cMax), where cMax is the
>>> first ghost cell.
>>> Now you still need a way to get rid of faces between ghost cells (which
>>> only occur in cells across a partition boundary).
>>> To do this, you use the "ghost" label we make during partitioning:
>>> ierr = DMPlexGetLabel(dm, "ghost", &ghostLabel);CHKERRQ(ierr);
>>> ierr = DMLabelGetValue(ghostLabel, face, &ghost);CHKERRQ(ierr);
>>> if (ghost >= 0) continue;
>>> What exactly is going wrong?
>>> Matt
>>> Thanks!
>>> John
>>> Dr John O'Sullivan
>>> Lecturer
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150327/7954c734/attachment.html>
