[petsc-dev] Error on large problems.
Mark Adams
mfadams at lbl.gov
Wed Mar 25 06:24:45 CDT 2015
On Sat, Mar 7, 2015 at 5:49 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Mar 7, 2015, at 4:27 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > On Sat, Mar 7, 2015 at 3:11 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > Hmm, my first guess is a mixup between PetscMPIInt and PetscInt
> arrays or MPIU_INT somewhere. (But compilers catch most of these)
> > I have a run with ~9K eq/core 128K cores many times but have never
> gotten the 32K/core (4B eq.) run to work. So it looks like an int overflow
> issue.
> Well in theory if we have done everything write with 64 bit indices
> there should never be an integer overflow (though of course there could be
> mistake somewhere but generally the compiler will detect if we are trying
> to stick a 64 bit int into a 32 bit slot.
> Can you try the same example without GAMG (say with hypre instead); if
> it goes through ok it might indicate an int issue either in gamg or the
> code that gamg calls?
Good idea, Jacobi works. I will try a stripped down GAMG next.
> Barry
> > Another possibility is bug in the MPI for many large messages; any
> chance you can run the same thing on a very different system? Mira?
> > Not soon, but I have Chombo and PETSc built on Mira and it would not be
> hard to get this code setup and try it.
> > This is for SCE15 so I will turn the PETSc test off unless someone has
> any ideas on something to try. I am using maint perhaps I should use
> master.
> > Mark
> > Barry
> > > On Mar 7, 2015, at 1:21 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > > I seem to be getting this error on Edison with 128K cores and ~4
> Billion equations. I've seen this error several time. I've attached a
> recent output from this. I wonder if it is an integer overflow. This
> built with 64 bit integers, but I notice that GAMG prints out N and I see
> N=0 for the finest level.
> > > Mark
> > > <out.131072.uniform.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150325/21ceaa83/attachment.html>
