[petsc-dev] actually, I think I did find and fix a bug in virs.c:SNESSolve_VINEWTONRSLS() [attached patch]
Ed Bueler elbueler at alaska.edu
Wed Mar 18 16:35:45 CDT 2015
Barry and Jed --
Actually, I think I do see a bug that has caused me some problems, namely
that when RSLS diverges, stuff is corrupt.  This seems to be because
DMDestroyVI() was not called when the diverged cause a "break" out of the
for loop in SNESSolve_VINEWTONRSLS().  Part of the problem was the indent
level. ;-)
I've decided to follow this advice:
*For very small changes you can clone the petsc repository, create a new
branch on your local repository from master, apply and commit your changes
there, and use git format-patch origin/master to create the patch. Send the
patch to petsc-dev at mcs.anl.gov.
The attached should explain itself, but note I branched off of
barry/snes-monitor-vi-residual, and thus did
   git format-patch barry/snes-monitor-vi-residual
to generate the patch.
Is this an easy to apply form, compared to me being confused about my fork?
Ed
Ed Bueler
Dept of Math and Stat and Geophysical Institute
University of Alaska Fairbanks
Fairbanks, AK 99775-6660
301C Chapman and 410D Elvey
907 474-7693 and 907 474-7199  (fax 907 474-5394)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150318/97077f51/attachment.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150318/97077f51/attachment.bin>
