[petsc-dev] More on FV overlap cells and Fortran
Matthew Knepley
knepley at gmail.com
Fri Mar 13 05:57:06 CDT 2015
On Fri, Mar 13, 2015 at 4:56 AM, John O'Sullivan <
jp.osullivan at auckland.ac.nz> wrote:
> Hi Matt,
> We're getting there with our parallel Fortran FV code. But here's another
> question about the best way to do things. Another simpleTest2 code is
> attached to demonstrate the question and below is a copy of the relevant
> part:
> <petsc-dev at mcs.anl.gov>! We worked out its important not to write to the
> parts of arrays that correspond to overlap cells.
> ! Following ex11 it would be done something like this using C:
> ! ierr = DMPlexPointGlobalRef(dm,c,x,&xc);CHKERRQ(ierr);
> ! if (xc) {ierr =
> (*mod->solution)(mod,0.0,cg->centroid,xc,mod->solutionctx);CHKERRQ(ierr);}
> ! And according to the documentation on DMPlexPointGlobalRef xc would be
> returned as null for
> ! the overlap blocks that don't belong to the processor
> ! We can achieve the same using the ghost labels on the overlap cells but
> is this a good
> ! idea? We'd prefer to follow the standard approach ie in ex11 but I don't
> think there's a
> ! clean way to do this in fortran as we can't pass pointers to
> structures...
> ! Could it be done with DMPlexPointGlobalRef? If so, any ideas?
I can do two things:
a) Make a Fortran version of DMPlexPointGlobalRef(), which returns an F90
array of size dof
or
b) Make a Fortran wrapper for DMPlexGetGlobalOffset_Internal(), which
returns start/end, and
start < 0 if its off-process
Tell me what you think is better. Also, you can see here that we are
experimenting with different
interfaces. Jed likes getting a pointer back. I like getting offsets back.
Matt
> do c = start_cell, end_interior_cell-1
> ! ??? call DMPlexPointGlobalRef(dm, c, localx, someref)???
> call DMLabelGetValue(label, c, ghost, ierr); CHKERRQ(ierr)
> if (ghost < 0) then
> call PetscSectionGetOffset(solution_section, c, cell_offset, ierr);
> CHKERRQ(ierr)
> cell_offset = cell_offset + 1
> localx(cell_offset) = 100.0
> end if
> end do
> Cheers!
> John
> Dr John O'Sullivan
> Lecturer
> Department of Engineering Science
> University of Auckland, New Zealand
> email: jp.osullivan at auckland.ac.nz <https://lists.mcs.anl.gov/mailman/listinfo/petsc-dev>
> tel: +64 (0)9 923 85353
> *From:* Matthew Knepley [mailto:knepley at gmail.com]
>> *Sent:* Friday, 13 March 2015 4:44 a.m.
>> *To:* John O'Sullivan
>> *Cc:* petsc-dev at mcs.anl.gov
>> *Subject:* Re: Simple Test example not working in parallel for
>> DMPlex/FV/overlap/ghost cells...
>> On Thu, Mar 12, 2015 at 4:19 AM, John O'Sullivan <
>> Hi Matt,
>> Attached is a simple test program where I'm loading the
>> simpleblock-100.exo and trying to set up a grid with closed boundaries on
>> all the outer faces.
>> Just so I understand what you want. You do not want any ghost cells made
>> around the outer boundary. What you have will do that.
>> We'd like to do it this way so we can use the same sort of architecture
>> as in PetscFVM to skip ghost faces when calculating fluxes (like you
>> suggested in your response yesterday)
>> Note that now, it will also mark the outer boundary faces as ghosts
>> because they have no partner cell.
>> It works fine on a single processor but when we run it on 2 processors
>> there's an indexing error when trying to create a matrix. There's obviously
>> something wrong with the way we're setting up the dm but I don't know what
>> it is? Or perrhaps we're not allowed to use DMPlexConstructGhostCells in
>> this way? Also I was surprised by the values given for end_interior_cell on
>> each processor as it seems to include the overlap cells which is not what I
>> expected?
>> This is a bug in my latest preallocation push. Thanks for finding it. I
>> pushed a fix for this, and for many Fortran things
>> to next. I am including my modified source so that everything is
>> deallocated correctly (run with -malloc_test).
>> It seems to work for me now. Let me know if you have problems.
>> Thanks,
>> Matt
>> One last thing, the FORTRAN interface for DMPlexCreateLabel was missing
>> so I added it into zplexlabel.c which works fine but I'm not sure if this
>> was the right way to do it. My version is attached.
>> The full output from the program for two processors is below.
>> Cheers
>> John
>> (ps Is there a way to make DMView output the Labels information for all
>> processors?)
>> $ mpirun -n 2 simpleTest2
>> DM Object:Parallel Mesh 2 MPI processes
>> type: plex
>> Parallel Mesh in 3 dimensions:
>> 0-cells: 12 16
>> 1-cells: 20 28
>> 2-cells: 11 16
>> 3-cells: 2 3
>> Labels:
>> ClosedBoundaries: 0 strata of sizes ()
>> Face Sets: 3 strata of sizes (2, 2, 5)
>> Cell Sets: 1 strata of sizes (2)
>> depth: 4 strata of sizes (12, 20, 11, 2)
>> DM Object: 2 MPI processes
>> type: plex
>> DM_0x7f91c1d27ff0_0 in 3 dimensions:
>> 0-cells: 12 16
>> 1-cells: 20 28
>> 2-cells: 11 16
>> 3-cells: 2 (0) 3 (0)
>> Labels:
>> ghost: 2 strata of sizes (1, 10)
>> vtk: 1 strata of sizes (1)
>> 0 3 3 19 35
>> 0 2 2 14 25
>> [1]PETSC ERROR: --------------------- Error Message
>> [1]PETSC ERROR: Argument out of range
>> [1]PETSC ERROR: Section point -1 should be in [1, 3)
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Argument out of range
>> [0]PETSC ERROR: Section point -3 should be in [0, 1)
>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> [0]PETSC ERROR: Petsc Development GIT revision: v3.5.3-2945-g6900bc9 GIT
>> Date: 2015-03-10 18:15:26 -0500
>> [0]PETSC ERROR: simpleTest2 on a arch-darwin-c-debug named
>> Johns-MacBook-Air.local by jposunz Thu Mar 12 22:01:26 2015
>> [0]PETSC ERROR: Configure options --download-fblaslapack --useThreads=0
>> --download-triangle --download-netcdf --download-exodusii --download-hdf5
>> --download-ptscotch --download-chaco
>> [0]PETSC ERROR: #1 PetscSectionGetDof() line 499 in
>> /Users/jposunz/projects/src/petsc/src/vec/is/utils/vsectionis.c
>> [0]PETSC ERROR: #2 DMPlexUpdateAllocation_Static() line 609 in
>> /Users/jposunz/projects/src/petsc/src/dm/impls/plex/plexpreallocate.c
>> [0]PETSC ERROR: #3 DMPlexPreallocateOperator() line 763 in
>> [0]PETSC ERROR: #4 DMCreateMatrix_Plex() line 746 in
>> /Users/jposunz/projects/src/petsc/src/dm/impls/plex/plex.c
>> [0]PETSC ERROR: [1]PETSC ERROR: See
>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>> [1]PETSC ERROR: Petsc Development GIT revision: v3.5.3-2945-g6900bc9 GIT
>> [1]PETSC ERROR: simpleTest2 on a arch-darwin-c-debug named
>> #5 DMCreateMatrix() line 958 in
>> /Users/jposunz/projects/src/petsc/src/dm/interface/dm.c
>> [1]PETSC ERROR: Configure options --download-fblaslapack --useThreads=0
>> [1]PETSC ERROR: #1 PetscSectionGetDof() line 499 in
>> [1]PETSC ERROR: #2 DMPlexUpdateAllocation_Static() line 609 in
>> [1]PETSC ERROR: #3 DMPlexPreallocateOperator() line 763 in
>> [1]PETSC ERROR: #4 DMCreateMatrix_Plex() line 746 in
>> [1]PETSC ERROR: #5 DMCreateMatrix() line 958 in
>> MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
>> with errorcode 63.
>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>> You may or may not see output from other processes, depending on
>> exactly when Open MPI kills them.
>> Dr John O'Sullivan
>> Lecturer
>> *From:* Matthew Knepley [knepley at gmail.com]
>> *Sent:* Thursday, 12 March 2015 3:06 a.m.
>> *Subject:* Re: [petsc-dev] DMPlex, Finite Volume, overlap and ghost
>> cells...
>> On Wed, Mar 11, 2015 at 3:34 AM, John O'Sullivan <
>> Hi all,
>> I've managed to get myself very confused about how to use DMPlex
>> correctly for a distributed Finite Volume grid...
>> My understanding was that along partition boundaries the ghost cells are
>> used store cell information from neighbouring partitions so that the fluxes
>> can be calculated.
>> Though debugging through ex11 it seems like overlap is set equal to 1?
>> I'm solving a simple pressure-diffusion equation on a 1D column (from an
>> exo grid) which works fine on a single processor but not in parallel. I'm
>> certainly not setting things up right or labeling correctly...
>> Could someone please explain the most appropriate way to set up and label
>> the DM, whether the overlap should be 0 or 1 and whether ghost cells should
>> be placed on internal partition boundaries.
>> Yes, for FV the partition overlap should be 1, as it is in ex11. This
>> means that when the partition happens, we will
>> put a layer of cells on the other side of partition boundaries,
>> When DMPlexConstructGhostCells() is called, it will put ghost cells on
>> the other side of the true boundary. Both
>> kinds of cells will be separated from interior cells by the
>> DMPlexGetHybridBounds(&cMax), where cMax is the
>> first ghost cell.
>> Now you still need a way to get rid of faces between ghost cells (which
>> only occur in cells across a partition boundary).
>> To do this, you use the "ghost" label we make during partitioning:
>> ierr = DMPlexGetLabel(dm, "ghost", &ghostLabel);CHKERRQ(ierr);
>> ierr = DMLabelGetValue(ghostLabel, face, &ghost);CHKERRQ(ierr);
>> if (ghost >= 0) continue;
>> What exactly is going wrong?
>> Matt
>> Thanks!
>> John
>> Dr John O'Sullivan
>> Lecturer
>> experiments lead.
>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150313/bb568c11/attachment.html>
