[petsc-dev] Bug in MatGetSubMatrix
hong at aspiritech.org
Mon Mar 9 12:44:35 CDT 2015
Stefano :
> There's a bug in MatGetSubMatrix; the case MAT_REUSE_MATRIX is not covered
> by the interface when isrow == iscol and isrow is a stride 1 IS
> representing the whole set of rows. A tentative patch is attached.
Actually, current code is correct. The case MAT_REUSE_MATRIX is covered:
if (n == rend-rstart) {
/* special case grabbing all rows; NEED to do a global
reduction to make sure all processes are doing this */
if (cll == MAT_INITIAL_MATRIX) {
*newmat = mat;
ierr =
PetscObjectReference((PetscObject)mat);CHKERRQ(ierr);
PetscFunctionReturn(0);
Since 'newmat' is same as 'mat' in this case, we do NOT create a newmat,
instead, assign it to the address of 'mat' in the case MAT_INITIAL_MATRIX,
i.e.,
'*newmat' = mat are the same matrix.
Whenever 'mat' is changed, so does '*newmat' ,
MatGetSubMatrix(C,isrow,NULL,MAT_REUSE_MATRIX,&A) does not need to do
anything.
I created a test ex181.c, attached below.
Hong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150309/70f4bf48/attachment.html>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150309/70f4bf48/attachment.bin>
