[petsc-dev] What should MatReset() do?
Dmitry Karpeyev
karpeev at mcs.anl.gov
Fri Mar 6 20:22:40 CST 2015
On Fri, Mar 6, 2015 at 6:03 PM Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Mar 6, 2015, at 4:41 PM, Jed Brown <jed at jedbrown.org> wrote:
> > Dmitry Karpeyev <karpeev at mcs.anl.gov> writes:
> >> This is trickier than it might appear: nonzerostate effectively counts
> the
> >> global number of nonzeros.
> No it does not. Note in MatZeroRows_SeqAIJ() when entries are deleted
> from the matrix we still increase the nonzerostate.
>From MatAssemblyEnd_MPIAIJ():
if ((!mat->was_assembled && mode == MAT_FINAL_ASSEMBLY) ||
!((Mat_SeqAIJ*)(aij->A->data))->nonew) {
PetscObjectState state = aij->A->nonzerostate + aij->B->nonzerostate;
ierr =
MPI_Allreduce(&state,&mat->nonzerostate,1,MPIU_INT64,MPI_SUM,PetscObjectComm((PetscObject)mat));CHKERRQ(ierr);
Barring MatZeroRows MATSEQAIJ matrices aij->A and aij->B will simply
increment their nonzerostates on each new nonzero insertion in
MatSetVAlues_SeqAIJ(), so the containing MATMPIAIJ M ends up with the total
number of nonzeros in its nonzerostate.
Now I reset my M. That will blow away aij->A and aij->B. I can now insert
the same number of nonzeros, but in a different pattern. M will end up
with the same nonzerostate as before the reset and confuse the PC, no?
This started out as a discussion about MatReset(), but I think this _may_
be a bug we are seeing in one of the elastic contact applications: PCASM
tries to rebuild itself with MAT_REUSE_MATRIX when subdomain matrices
actually have different numbers of nonzeros. I have to say I haven't
ascertained that an inconsistent nonzerostate cases the problem, yet --
reproducible test cases that trigger the problem are still too big to debug.
> >> The PC will rebuild if its state is stale, but
> >> it will reuse matrices (e.g., subdomain matrices in PCASM) if
> nonzerostate
> >> is up to date. This works if the sparsity pattern never drops nonzeros,
> >> but that's no longer true if reset is allowed. I can reset a matrix,
> >> preallocate and assemble it so that the global number of nonzeros will
> be
> >> the same as before the resetting, but local sparsity patterns will
> change.
> >> This could happen, for example, when I have moving particles or, less
> >> exotically, when I have elastic contact and nodes move past each other.
> >> That will break PCASM.
> Just increase the nonzerostate flag by one on a reset (that is there is
> no reason to ever set it back to zero). Now nonzerostate is monotonically
> increasing.
> Barry
> Barry
> > On pretty simple and reliable solution would be to take a cryptographic
> > hash of the row/col arrays. I assume BG is really atrocious at hashing,
> > but is it so bad that this is not viable? (There are several places
> > where we use kinda fragile state counters or trust the user, but hashes
> > would make rebuilding more reliable and transparent.)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150307/b7d85a30/attachment.html>
