[petsc-dev] external package ML and 64 bit
Barry Smith
bsmith at mcs.anl.gov
Thu Mar 5 11:35:58 CST 2015
Matt,
Please don't put such fixes into random branches you happen to be working on (like knepley/feature-parallel-configure). It is better to go directly into their only little branch.
Your fix doesn't work. I have pushed a fix in the branch barry/error-on-64bitindices-with-ml and merged into next. Also explained why 64 bit indices with ML are not going to happen in ml.py
self.requires32bitint = 1; # ml uses a combination of "global" indices that can be 64 bit and local indices that are always int therefore it is
# essentially impossible to use ML's 64 bit integer mode with PETSc's --with-64-bit-indices
Note: also this is the "Trilinos style" of having these two kinds of indices. I debated doing this with PETSc but felt it was too complex with little payoff.
Barry
> On Mar 5, 2015, at 11:02 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Mar 5, 2015 at 11:01 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Matt,
> Please ALWAYS list the branch(s)/commit that you did this in when you say you "pushed a fix"
> https://bitbucket.org/petsc/petsc/commits/ba4f728f6c00f645cbd73e74de34ed390600afde
> Matt
> Barry
> > On Mar 5, 2015, at 9:12 AM, Matthew Knepley <knepley at gmail.com> wrote:
> > I pushed a fix.
> > Matt
> > On Thu, Mar 5, 2015 at 2:18 AM, Stefano Zampini <stefano.zampini at gmail.com> wrote:
> > PETSc is broken when configured with --download-ml --with-64-bit-indices.
> > ML has support for 64 bit integers (using ML's configure flag --with-ml-64bit-integer) but one needs to specify the type of 64 bit integer (long long or long or whatever...)
> > Better to turn off 64 bit builds of ML before adding support for it during configure.
> > Stefano
> > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> > -- Norbert Wiener
> -- Norbert Wiener
