[petsc-dev] PETSc VecView with MPIIO and complex numbers broken?
Dave May
dave.mayhem23 at gmail.com
Mon Mar 2 22:39:44 CST 2015
Hi Barry,
I fixed all the PetscPrintf's to have the (double) cast.
I am wondering if this could this be an uninitialized variable issue?
In that code, I have the following declaration
const PetscScalar test_values[] = { 0.311256, 88.068, 11.077444,
9953.62, 7.345, 64.8943, 3.1458, 6699.95, 0.00084, 0.0647 };
which is then used to build a Vec object.
I am not explicitly setting the imaginary part of the vector to zero when
test_values is declared.
Apologize for the crappy code - I really never ever use complex numbers in
petsc.
If this is in fact the issue, please note that the same time of declaration
appears at the top of
petsc / src / dm / examples / tutorials / ex15.c
Cheers
Dave
On 2 March 2015 at 20:31, Barry Smith <bsmith at mcs.anl.gov> wrote:
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/03/01/examples_master_arch-opensolaris-cmplx-pkgs-dbg_n-gage.log
> ******* Testing: testexamples_C *******
> 4,7c4,7
> < min(a) = +8.40e-04 [loc 8]
> < max(a) = +9.95e+03 [loc 3]
> < min(b) = +8.40e-04 [loc 8]
> < max(b) = +9.95e+03 [loc 3]
> > min(a) = -4.21e+207 [loc 6]
> > max(a) = +8.10e-320 [loc 5]
> > min(b) = -4.21e+207 [loc 6]
> > max(b) = +8.10e-320 [loc 5]
> /export/home/petsc/petsc.clone-3/src/vec/vec/examples/tests
> Possible problem with with ex46, diffs above
> 4,7c4,7
> Possible problem with with ex46_2, diffs above
> 4,7c4,7
> Possible problem with with ex46_3, diffs above
> 6,9c6,9
> Possible problem with with ex46_mpiio, diffs above
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150303/98ffcefe/attachment.html>
