[petsc-dev] failure of new parallel configure
Barry Smith
bsmith at mcs.anl.gov
Mon Mar 2 18:05:00 CST 2015
$ ./configure --download-mpich --with-threadsafety --with-openmp --with-log=0
Configuring PETSc to compile on your system
=============================================================================== Trying to download http://www.mpich.org/static/downloads/3.1.3/mpich-3.1.3.tar.gz for MPICH =============================================================================== =============================================================================== Trying to download http://ftp.mcs.anl.gov/pub/petsc/externalpackages/mpich-3.1.3.tar.gz for MPICH =============================================================================== =============================================================================== Running configure on MPICH; this may take several minutes =============================================================================== =============================================================================== Running make on MPICH; this may take several minutes =============================================================================== =============================================================================== Running make install on MPICH; this may take several minutes =============================================================================== TESTING: output from config.setCompilers(config/BuildSystem/config/setCompilers.py:1451) *******************************************************************************
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150302/33779195/attachment.obj>
