[petsc-dev] Seeking OLCF users complaining about poor build times
Jed Brown jed at jedbrown.org
Mon Mar 2 11:22:58 CST 2015
Matthew Knepley <knepley at gmail.com> writes:
> I just pushed an update for parallel configure (using only 2 threads right
> now) to next. We will see if the
> builds blow up.
Hmm, the configure cases in 'next' are intended to succeed.  The hard
part of parallel configure is having understandable diagnostics on
error.  How are you testing that?
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150302/30a20a1c/attachment.sig>
