[petsc-dev] ksp/ex56 broken in next
Jed Brown
jed at jedbrown.org
Sun Mar 1 15:28:38 CST 2015
Sorry, all. I have fixed the bstash issue reported here.
Barry Smith <bsmith at mcs.anl.gov> writes:
> This has been broken since Jed merged his buggy branch into next. It has been reported to Jed repeatedly.
>> On Feb 27, 2015, at 6:45 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> Jed, I see this in next, but I am puzzled, I tested a week ago (did I forget to test next?), and I do not see this commit in next, or master, with SourceTree.
>> 07:35 (5ab6ef6...)|BISECTING ~/Codes/petsc$ git bisect good
>> ee5fc33bea6969d0579ded3dbfac725151deab42 is the first bad commit
>> commit ee5fc33bea6969d0579ded3dbfac725151deab42
>> Author: Jed Brown <jedbrown at mcs.anl.gov>
>> Date: Wed Dec 4 13:00:40 2013 -0700
>> VecAssembly BTS: enable by default, use -vec_assembly_bts 0 to disable
>> Note that -vec_assembly_bts can only be disabled if VecSetFromOptions is
>> called, which it often is not. Hopefully the old stash communication
>> routines can be deleted soon, and then all the options go away.
>> :040000 040000 388f1fa7e4c763cdb65caf22fa1f42970a73a5e7 7ccce92e0efa7184c23fe507942d273a1ac89665 M src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150301/2d849921/attachment.sig>
