[petsc-dev] PETSc release based on master before 9 pm tonight
Eric Chamberland Eric.Chamberland at giref.ulaval.ca
Tue Jun 9 08:40:50 CDT 2015
On 06/08/2015 04:54 PM, Satish Balay wrote:
> Please do check src/docs/website/documentation/changes/dev.html and
> update it with any missing changes entries..
> http://www.mcs.anl.gov/petsc/documentation/changes/dev.html
> thanks,
> Satish
> On Mon, 8 Jun 2015, Barry Smith wrote:
>>    If the nightly tests run (which they now should) Satish will be making the release maint branch and tarball Tuesday morning at 9am. Please do not make any additional changes to master until then unless you absolutely know the fixes are needed and don't break anything.
>>     Barry
Maybe support for Cholesky with MKL_PARDISO should be mentioned?
  (ref:
https://bitbucket.org/petsc/petsc/pull-request/311/modification-for-sbaij-support-with-mkl/diff)
Eric
