[petsc-dev] [Ideas-team] Seeking OLCF users complaining about poor build times
Jed Brown
jed at jedbrown.org
Fri Feb 27 12:00:39 CST 2015
Barry Smith <bsmith at mcs.anl.gov> writes:
> Actually the parallel compiles of the 1000+ files on the "regular"
> filesystems at ANL and LBL is taking less than 2 minutes so I can't
> blame the filesystem bandwidth.
I think bandwidth is adequate, but latency (especially for metadata) is
rather high. Normal make uses parallelism to mitigate, but configure is
sequential, so gets hit harder.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150227/9f7fc461/attachment.sig>
