[petsc-dev] [Ideas-team] Seeking OLCF users complaining about poor build times
Satish Balay
balay at mcs.anl.gov
Fri Feb 27 10:45:20 CST 2015
On Fri, 27 Feb 2015, Todd Gamblin wrote:
> Barry:
> I remember that ALCF attempted to address this problem at one point or
> another with "tmpicc" compiler wrappers. As I remember the idea was that
> they stored the compiler's tmp files in some local storage on the login
> node. I think that was back when ANL's main machine was Intrepid, and I
> don't know where those compilers went on Mira. Do you remember this?
No idea about tmpicc thingy - but current compilers appear to use /tmp
And one can change this with TMPDIR env variable.
> In general I'm not sure that just moving the compiler temp files is going
> to cut it. I think you really want to do the build out of /tmp or some
> other filesystem. Spack does this automatically for its builds -- on LLNL
> machines I build much faster by just finding the local tmp space and using
> it for all the builds. Spack is also able to put the entire build out in
> tmp space, because you just tell it the software name, and it handles the
> details of where it is downloaded and expanded. It's not perfect, because
> it looks at $TMP, $TMPDIR, and some other LLNL-specific places.
> If it turns out that configuring NFS (or in ANL's case, I think it's GPFS)
> to be fast on a set of loaded login nodes is not feasible, it might be
> nice to have some kind of recommendations for build staging.
Yeah - we've been doing our build in /tmp [later ANL/MCS standardized
this usage by providing /sandbox - slightly different from /tmp] for
many years.
Its just that users won't think of doing this. [also we usually
default to inplace build - and use /tmp for build - works well with
--prefix install].
Also I think such usage at LC centers might be prohibited. And some
systems are configured in such a way that /tmp is really not useful
for source builds. [For eg - configure tends to do simpile runs - that
get blocked due to security settings on /tmp]
Satish
> -Todd
> On 2/27/15, 8:09 AM, "David E. Bernholdt" <bernholdtde at ornl.gov> wrote:
> >Barry, thanks, this is extremely helpful. I'll have the OLCF folks
> >contact Nathan if they need any further info or have other experiments
> >to try.
> >On 02/27/2015 11:03 AM, Barry Smith wrote:
> >> Same text also in the attachment.
> >> Barry
> >> David,
> >> Nathan Collier has kindly run a test on Titan, Satish on Mira and
> >>Hopper, and Victor on Ranger with a basic optimized build of PETSc (all
> >>C code)
> >> Please find below some configure and make timings from the latest
> >>PETSc master.
> >> The Titan times for both configure and make are unacceptable. For
> >>total build time Titan is 3.5 times slower than Mira and Hopper and at
> >>least 10 times slower than laptops. The "time" results on Titan are
> >>disturbing
> >> configure
> >> real 14m32.169s (since the user + sys time is much less than real
> >>time, what is it waiting on?)
> >> user 1m51.527s
> >> sys 3m40.734s
> >> make
> >> real 15m56.004s
> >> user 8m8.971s
> >> sys 52m42.734s (why so much?)
> >> which I read as either the filesystem or the compiler system (location
> >>of the compilers, license server of the compilers, ...) is really badly
> >>configured.
> >> The Hopper configure time with the default
> >>TMPDIR=/scratch/scratchdirs/balay is is unacceptable but if you actually
> >>use the real /tmp it becomes somewhat reasonable.
> >> Feel free to share this information with local experts,
> >> I suggest you view the below table in a fixed width font editor like
> >>Emacs or Vi so the columns line up.
> >> configure time make time Total compilers
> >> filesystem
> >> Titan 14m32s 15m56s 30m28s Intel 14
> >> /lustre/atlas1/geo103/proj-shared/
> >> 41m38s 9m5s 50m43s
> >> /ccs/home/ (no load on login node)
> >> 13m
> >>(no load on a different login node)
> >> Mira 6m59s 1m49s 8m48s IBM
> >> /gpfs/mira-home/
> >> Hopper 23m17 1m45s 25m2s
> >> /global/u2/b/balay/petsc.clone default
> >> 6m17s 1m39s 7m57s manually
> >>set TMPDIR=/tmp
> >> NSF Ranger UT Austin 5m10s 1m28s 6m38s
> >> default, whatever it is
> >> Linux laptop 53s 1m13s 2m6s Gnu
> >> compile and compiler local
> >> Apple laptop 1m14s 54s 2m8s clang
> >> Linux workstation 1m11s 22s 1m33s Gnu
> >> 1m37s 29s 2m6s Gnu
> >> compile directory local; compiler directory remote
> >> 3m11s 25s 3m36s Intel 13
> >> PETSc has about 1000 source files that need compiling
> >> The configure is essentially sequential, the make extremely parallel.
> >> During configure the source code is on the listed file system, all .o
> >>and executables are on /tmp
> >> During the make the source code and all .o are on the listed file system
> >>> On Feb 25, 2015, at 11:23 AM, David E. Bernholdt
> >>> At the kick-off meetings, one of the general complaints I heard
> >>> expressed about the facilities was the slow build times compared to
> >>> personal systems.
> >>> If you have this complaint and are an OLCF user, and are willing to
> >>>work
> >>> with us a little to try to understand your experience in more detail,
> >>> please contact me (individually, not reply-all).
> >>> This is a facility thing, not an IDEAS thing, so I can't speak for the
> >>> other facilities. But we've recently received some other similar
> >>> comments, and we're trying to dig into what's happening.
> >>> Thanks
> >>> David E. Bernholdt | Email: bernholdtde at ornl.gov
> >>> Oak Ridge National Laboratory | Phone: +1 865-574-3147
> >>> http://www.csm.ornl.gov/~bernhold | Fax: +1 865-576-5491
> >>> _______________________________________________
> >>> Ideas-team mailing list
> >>> Ideas-team at lists.mcs.anl.gov
> >>> https://lists.mcs.anl.gov/mailman/listinfo/ideas-team
