[petsc-dev] Seeking OLCF users complaining about poor build times
Satish Balay
balay at mcs.anl.gov
Thu Feb 26 17:47:03 CST 2015
And the following is for hopper at nersc. Note: the TMPDIR is on
luster - so that might be contributing to long times - I'll have to
redo some of this with a different TMPDIR
Satish
hopper.nersc MAKE_NP = 13
balay at hopper03:~/petsc.clone> time ./reconfigure-arch-cray-xt6-pkgs-opt.py
real 58m13.350s
user 18m8.168s
sys 28m3.945s
balay at hopper03:~/petsc.clone> time make PETSC_DIR=/global/u2/b/balay/petsc.clone PETSC_ARCH=arch-cray-xt6-pkgs-opt all
real 1m40.348s
user 12m5.281s
sys 1m38.422s
balay at hopper03:~/petsc.clone> uptime
15:45pm up 8 days 0:55, 22 users, load average: 2.37, 3.14, 2.42
balay at hopper03:~/petsc.clone> cat reconfigure-arch-cray-xt6-pkgs-opt.py
#!/usr/bin/python
if __name__ == '__main__':
import sys
import os
sys.path.insert(0, os.path.abspath('config'))
import configure
configure_options = [
'--COPTFLAGS=-fast -mp',
'--CXXOPTFLAGS=-fast -mp',
'--FOPTFLAGS=-fast -mp',
'--download-hypre',
'--download-metis',
'--download-parmetis',
'--download-superlu_dist',
#'--with-blas-lapack-lib=-L/opt/acml/5.3.1/pgi64/lib -lacml',
'--download-fblaslapack',
'--with-cc=cc',
'--with-clib-autodetect=0',
'--with-cxx=CC',
'--with-cxxlib-autodetect=0',
'--with-debugging=0',
'--with-fc=ftn',
'--with-fortranlib-autodetect=0',
'--with-shared-libraries=0',
'--with-x=0',
'--with-c2html=0',
'PETSC_ARCH=arch-cray-xt6-pkgs-opt',
configure.petsc_configure(configure_options)
On Thu, 26 Feb 2015, Satish Balay wrote:
> Attaching logs.
> Note: 'uptime' is run a bit after the builds completed..
> Satish
> mira.alcf build: MAKE_NP = 32
> [balay at miralac1 petsc.maint.35]$ time ./reconfigure-arch-time-test.py
> <snip>
> real 25m57.240s
> user 17m33.944s
> sys 6m41.065s
> [balay at miralac1 petsc.maint.35]$ time make PETSC_DIR=/gpfs/mira-home/balay/petsc.maint.35 PETSC_ARCH=arch-time-test all
> <snip>
> real 1m39.067s
> user 22m56.248s
> sys 7m42.658s
> [balay at miralac1 petsc.maint.35]$ uptime
> 21:50:08 up 10 days, 2:14, 87 users, load average: 3.86, 5.02, 5.03
> Laptop build: MAKE_NP = 4
> $ time ./configure --download-hypre --download-metis --download-parmetis --download-superlu_dist --download-fblaslapack --with-debugging=0 --with-c2html=0 PETSC_ARCH=arch-test COPTFLAGS="-O3 -fast" FOPTFLAGS="-O3 -fast" CXXOPTFLAGS="-O3 -fast"
> <snip>
> real 3m56.755s
> user 2m47.458s
> sys 0m57.206s
> $ time make PETSC_DIR=/home/balay/petsc PETSC_ARCH=arch-test all
> <snip>
> real 1m13.519s
> user 3m40.708s
> sys 0m47.002s
> $ uptime
> 15:50:32 up 3 days, 5:20, 11 users, load average: 0.05, 0.30, 0.49
> [balay at miralac1 petsc.maint.35]$ cat reconfigure-arch-time-test.py
> #!/usr/bin/python
> import sys
> import os
> import configure
> '--download-hypre=1',
> '--download-metis=1',
> '--download-parmetis=1',
> '--download-superlu_dist=1',
> #'--with-blas-lapack-lib=-L/soft/libraries/alcf/current/xl/LAPACK/lib -llapack -L/soft/libraries/alcf/current/xl/BLAS/lib -lblas',
> '--download-fblaslapack=1',
> '--with-c2html=0',
> '--with-cc=mpixlc_r',
> '--with-cxx=mpixlcxx_r',
> '--with-fc=mpixlf77_r -qnosave',
> '--with-x=0',
> '-COPTFLAGS= -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction',
> '-CXXOPTFLAGS= -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction',
> '-FOPTFLAGS= -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction',
> 'PETSC_ARCH=arch-time-test',
> > > > > On Feb 26, 2015, at 8:13 AM, Nathan Collier <nathaniel.collier at gmail.com>
> > > > wrote:
> > > > > Ok, so I built PETSc with metis, parmetis, superlu_dist, and hyper on
> > > > Titan. The configure time is the second configure--when you run the
> > > > reconfigure script that the batch submission generates for you.
> > > > > configure: 38m15.488s
> > > > > make: 15m37.610s
Type: application/gzip
Desc:
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150226/16d953e6/attachment.bin>
Desc:
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150226/16d953e6/attachment-0001.bin>
