[petsc-dev] Seeking OLCF users complaining about poor build times
Barry Smith
bsmith at mcs.anl.gov
Thu Feb 26 17:25:26 CST 2015
Nathan,
Could you please run two more configurations. Same but without the external packages and then same (including external packages) with the master branch.
The permutations are becoming more interesting.
Thanks
Barry
> On Feb 26, 2015, at 2:40 PM, Nathan Collier <nathaniel.collier at gmail.com> wrote:
> Barry,
> * see attached configure log
> * times are the "real time" reported by the unix time command
> * all the packages should rebuild because the reconfigure script has a --with-clean=1
> * not sure about the load while configuring, if you can tell me how to check this I can run again and monitor it
> Nate
> On Thu, Feb 26, 2015 at 3:15 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Nathan,
> Any idea what the load was on the compiler server during the configure/make ?
> Barry
> > On Feb 26, 2015, at 8:13 AM, Nathan Collier <nathaniel.collier at gmail.com> wrote:
> > Ok, so I built PETSc with metis, parmetis, superlu_dist, and hyper on Titan. The configure time is the second configure--when you run the reconfigure script that the batch submission generates for you.
> > configure: 38m15.488s
> > make: 15m37.610s
> > Nate
> > On Thu, Feb 26, 2015 at 2:28 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > I think we made some progress in improving build times.
> > We have some of the externalpackages building using parallel make - so
> > that part is faster now. [ Some of this stuff might be in master - but
> > not 3.5]
> > Some packages are still built sequentially [for eg:
> > fblaslapack,scalapack,superlu etc]. Fixing them can reduce build time
> > significantly. [esp if the machine has many cores]
> > The sequential configure [of all packages] is still the
> > bottleneck. All compiles [by PETSc configure] are done in TMPDIR to
> > avoid NFS I/O.
> > Reducing the number of tests done in configure won't be easy. I have a
> > minor fix that avoids unnecessary compiles wrt externalpackages in
> > branch 'balay/update-configure-lib-search'
> > BTW: I don't have access to oakridge machines..
> > Satish
> > On Wed, 25 Feb 2015, Barry Smith wrote:
> > > Shockingly this is not bad (though more than it should be), we've seen times like an hour on the NERSC and ANL systems.
> > > If you have time :-) could you run with metis, permetis, superlu_dist and hypre --with-debugging=0 and get the times separately for configure and make?
> > > Thanks
> > > Barry
> > > > On Feb 25, 2015, at 9:05 PM, Nathan Collier <nathaniel.collier at gmail.com> wrote:
> > > > I have built on Titan, I can time my configure for more accurate answers but I would say it was on the order of 10-15 minutes. That is with a Metis/parmetis build. Is this the type of experience you are looking for? More details?
> > > > Nate
> > > > On Wednesday, February 25, 2015, Victor Eijkhout <eijkhout at tacc.utexas.edu> wrote:
> > > > > On Feb 25, 2015, at 1:27 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > > > If you have accounts there and can reproduce slow configure/make times
> > > > Just let me know if you want a comparison to TACC machines.
> > > > Starting with Ranger, we gave our build node its own file system because I regularly crashed lustre with the petsc build. No fault of Petsc.
> > > > And I have no complaints about the configure/make speed, on either our build node or the regular user file system.
> > > > Victor.
> <configure.log>
