[petsc-dev] funny error on osx
Satish Balay
balay at mcs.anl.gov
Thu Feb 26 16:35:14 CST 2015
Looks like your hostnmae is 'MacBook-Pro.local' [verify with 'hostname' command mentioned below]
So - I would expect the following line in /etc/hosts
127.0.0.1 MacBook-Pro.local
But I don't see this in the text quoted below.
Satish
On Thu, 26 Feb 2015, Mark Adams wrote:
> Added this but not luck:
> # Host Database
> # localhost is used to configure the loopback interface
> # when the system is booting. Do not change this entry.
> 127.0.0.1 localhost
> 255.255.255.255 broadcasthost
> ::1 localhost
> markadams at MacBook-Pro.local /Users/markadams
> On Thu, Feb 26, 2015 at 5:22 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > If you are mssing with dns - try the following.
> > 1. check your hostname
> > 2. make sure you have an entry for this name in /etc/hosts file.
> > [It works for linux - and I think it should work for Mac aswell.]
> > For eg:
> > balay at asterix /home/balay
> > $ hostname
> > asterix
> > $ grep asterix /etc/hosts
> > 127.0.0.1 asterix localhost localhost.localdomain localhost4
> > localhost4.localdomain4
> > ::1 asterix localhost localhost.localdomain localhost6
> > localhost6.localdomain6
> > Satish
> > > I turned off wi-fi and got the same results.
> > > I did mess around with my DNS servers and such in trying to fix my wi-fi
> > > problems.
> > > On Thu, Feb 26, 2015 at 5:09 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > > I get this problem when I am on VPN or some strange public Wi-fi's
> > (like
> > > > at my public library).
> > > > When on these funny networks I just turn off wi fi while running
> > tests.
> > > > Barry
> > > > > On Feb 26, 2015, at 4:03 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > > > > Humm, funny. Never had this problem until a week ago or so. Did
> > > > something change?
> > > > > I need to run test and use the makefiles. This is a pain to change
> > them.
> > > > > I have had wi-fi problem on Yosemite, maybe I did something to screw
> > > > this up?
> > > > > Thanks,
> > > > > Mark
> > > > > On Thu, Feb 26, 2015 at 4:25 PM, Matthew Knepley <knepley at gmail.com>
> > > > wrote:
> > > > > It can't run gethostbyname(), so maybe you are not connected to a
> > > > network?
> > > > > If you want to remain disconnected, use mpirun -n 2 -host
> > > > localhost,localhost
> > > > > which is how I run my tests.
> > > > > Matt
> > > > > On Thu, Feb 26, 2015 at 3:16 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > > > > I started getting this error on master. I have no threads as far as
> > I
> > > > can see.
> > > > > Mark
> > > > > 16:14 mark/gamg-remove-eig-est
> > > > ~/Codes/petsc/src/ksp/ksp/examples/tutorials$ make runex55
> > > > > 1,8c1,40
> > > > > < 0 KSP Residual norm 162.78
> > > > > < 1 KSP Residual norm 25.4723
> > > > > < 2 KSP Residual norm 2.96171
> > > > > < 3 KSP Residual norm 0.460234
> > > > > < 4 KSP Residual norm 0.0651141
> > > > > < 5 KSP Residual norm 0.00705928
> > > > > < 6 KSP Residual norm 0.0016868
> > > > > < 7 KSP Residual norm 0.000213352
> > > > > > Fatal error in MPI_Init_thread: Other MPI error, error stack:
> > > > > > MPIR_Init_thread(498)..............:
> > > > > > MPID_Init(177).....................: channel initialization failed
> > > > > > MPIDI_CH3_Init(89).................:
> > > > > > MPID_nem_init(320).................:
> > > > > > MPID_nem_tcp_init(171).............:
> > > > > > MPID_nem_tcp_get_business_card(418):
> > > > > > MPID_nem_tcp_init(377).............: gethostbyname failed,
> > > > MacBook-Pro.local (errno 1)
> > > > > > = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> > > > > > = PID 78010 RUNNING AT MacBook-Pro.local
> > > > > > = EXIT CODE: 1
> > > > > > = CLEANING UP REMAINING PROCESSES
> > > > > > = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> > > > > /Users/markadams/Codes/petsc/src/ksp/ksp/examples/tutorials
> > > > > Possible problem with ex55, diffs above
> > > > > What most experimenters take for granted before they begin their
> > > > experiments is infinitely more interesting than any results to which
> > their
> > > > experiments lead.
> > > > > -- Norbert Wiener
