[petsc-dev] funny error on osx
Dave May dave.mayhem23 at gmail.com
Thu Feb 26 16:28:28 CST 2015
It looks like your aren't specifying to download an mpi implementation. So
on Mac it's presumably picking up the crap already installed on your
computer by apple. I've never found this works. I always request petsc
configure download openmpi. This works for me.
Dave
On Thursday, 26 February 2015, Mark Adams <mfadams at lbl.gov> wrote:
> Humm, this did not seem to work:
> 17:15 mark/gamg-remove-eig-est
> ~/Codes/petsc/src/ksp/ksp/examples/tutorials$ make runex55
> 1,8c1,2
> <   0 KSP Residual norm 162.78
> <   1 KSP Residual norm 25.4723
> <   2 KSP Residual norm 2.96171
> <   3 KSP Residual norm 0.460234
> <   4 KSP Residual norm 0.0651141
> <   5 KSP Residual norm 0.00705928
> <   6 KSP Residual norm 0.0016868
> <   7 KSP Residual norm 0.000213352
> > [mpiexec at MacBook-Pro.local] HYDU_sock_is_local (utils/sock/sock.c:532):
> gethostbyname error on MacBook-Pro.local: Unknown host
> > [mpiexec at MacBook-Pro.local] main (ui/mpich/mpiexec.c:291): unable to
> check if localhost is local
> /Users/markadams/Codes/petsc/src/ksp/ksp/examples/tutorials
> Possible problem with ex55, diffs above
> On Thu, Feb 26, 2015 at 4:25 PM, Matthew Knepley <knepley at gmail.com
> <javascript:_e(%7B%7D,'cvml','knepley at gmail.com');>> wrote:
>> It can't run gethostbyname(), so maybe you are not connected to a network?
>> If you want to remain disconnected, use mpirun -n 2 -host
>> localhost,localhost
>> which is how I run my tests.
>>   Matt
>> On Thu, Feb 26, 2015 at 3:16 PM, Mark Adams <mfadams at lbl.gov
>> <javascript:_e(%7B%7D,'cvml','mfadams at lbl.gov');>> wrote:
>>> I started getting this error on master.  I have no threads as far as I
>>> can see.
>>> Mark
>>> 16:14 mark/gamg-remove-eig-est
>>> 1,8c1,40
>>> > Fatal error in MPI_Init_thread: Other MPI error, error stack:
>>> > MPIR_Init_thread(498)..............:
>>> > MPID_Init(177).....................: channel initialization failed
>>> > MPIDI_CH3_Init(89).................:
>>> > MPID_nem_init(320).................:
>>> > MPID_nem_tcp_init(171).............:
>>> > MPID_nem_tcp_get_business_card(418):
>>> > MPID_nem_tcp_init(377).............: gethostbyname failed,
>>> MacBook-Pro.local (errno 1)
>>> > =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
>>> > =   PID 78010 RUNNING AT MacBook-Pro.local
>>> > =   EXIT CODE: 1
>>> > =   CLEANING UP REMAINING PROCESSES
>>> > =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150226/4524a541/attachment.html>
