[petsc-dev] funny error on osx
Mark Adams
mfadams at lbl.gov
Thu Feb 26 16:20:29 CST 2015
Humm, this did not seem to work:
17:15 mark/gamg-remove-eig-est
~/Codes/petsc/src/ksp/ksp/examples/tutorials$ make runex55
1,8c1,2
< 0 KSP Residual norm 162.78
< 1 KSP Residual norm 25.4723
< 2 KSP Residual norm 2.96171
< 3 KSP Residual norm 0.460234
< 4 KSP Residual norm 0.0651141
< 5 KSP Residual norm 0.00705928
< 6 KSP Residual norm 0.0016868
< 7 KSP Residual norm 0.000213352
> [mpiexec at MacBook-Pro.local] HYDU_sock_is_local (utils/sock/sock.c:532):
gethostbyname error on MacBook-Pro.local: Unknown host
> [mpiexec at MacBook-Pro.local] main (ui/mpich/mpiexec.c:291): unable to
check if localhost is local
/Users/markadams/Codes/petsc/src/ksp/ksp/examples/tutorials
Possible problem with ex55, diffs above
On Thu, Feb 26, 2015 at 4:25 PM, Matthew Knepley <knepley at gmail.com> wrote:
> It can't run gethostbyname(), so maybe you are not connected to a network?
> If you want to remain disconnected, use mpirun -n 2 -host
> localhost,localhost
> which is how I run my tests.
> Matt
> On Thu, Feb 26, 2015 at 3:16 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> I started getting this error on master. I have no threads as far as I
>> can see.
>> Mark
>> 16:14 mark/gamg-remove-eig-est
>> 1,8c1,40
>> > Fatal error in MPI_Init_thread: Other MPI error, error stack:
>> > MPIR_Init_thread(498)..............:
>> > MPID_Init(177).....................: channel initialization failed
>> > MPIDI_CH3_Init(89).................:
>> > MPID_nem_init(320).................:
>> > MPID_nem_tcp_init(171).............:
>> > MPID_nem_tcp_get_business_card(418):
>> > MPID_nem_tcp_init(377).............: gethostbyname failed,
>> MacBook-Pro.local (errno 1)
>> > = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
>> > = PID 78010 RUNNING AT MacBook-Pro.local
>> > = EXIT CODE: 1
>> > = CLEANING UP REMAINING PROCESSES
>> > = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150226/be9ffea5/attachment.html>
