[petsc-dev] funny error on osx
Mark Adams
mfadams at lbl.gov
Thu Feb 26 16:03:07 CST 2015
Humm, funny. Never had this problem until a week ago or so. Did something
change?
I need to run test and use the makefiles. This is a pain to change them.
I have had wi-fi problem on Yosemite, maybe I did something to screw this
up?
On Thu, Feb 26, 2015 at 4:25 PM, Matthew Knepley <knepley at gmail.com> wrote:
> It can't run gethostbyname(), so maybe you are not connected to a network?
> If you want to remain disconnected, use mpirun -n 2 -host
> localhost,localhost
> which is how I run my tests.
> Matt
> On Thu, Feb 26, 2015 at 3:16 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> I started getting this error on master. I have no threads as far as I
>> can see.
>> Mark
>> 16:14 mark/gamg-remove-eig-est
>> ~/Codes/petsc/src/ksp/ksp/examples/tutorials$ make runex55
>> 1,8c1,40
>> < 0 KSP Residual norm 162.78
>> < 1 KSP Residual norm 25.4723
>> < 2 KSP Residual norm 2.96171
>> < 3 KSP Residual norm 0.460234
>> < 4 KSP Residual norm 0.0651141
>> < 5 KSP Residual norm 0.00705928
>> < 6 KSP Residual norm 0.0016868
>> < 7 KSP Residual norm 0.000213352
>> > Fatal error in MPI_Init_thread: Other MPI error, error stack:
>> > MPIR_Init_thread(498)..............:
>> > MPID_Init(177).....................: channel initialization failed
>> > MPIDI_CH3_Init(89).................:
>> > MPID_nem_init(320).................:
>> > MPID_nem_tcp_init(171).............:
>> > MPID_nem_tcp_get_business_card(418):
>> > MPID_nem_tcp_init(377).............: gethostbyname failed,
>> MacBook-Pro.local (errno 1)
>> > = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
>> > = PID 78010 RUNNING AT MacBook-Pro.local
>> > = EXIT CODE: 1
>> > = CLEANING UP REMAINING PROCESSES
>> > = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
>> /Users/markadams/Codes/petsc/src/ksp/ksp/examples/tutorials
>> Possible problem with ex55, diffs above
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150226/42cba2c7/attachment.html>
