[petsc-dev] missing scalapack lib
Satish Balay
balay at mcs.anl.gov
Thu Feb 26 01:25:56 CST 2015
This fix [with a bit more configure cleanup] is in balay/update-configure-lib-search branch.
i.e - if you specify --download-scalapack - the newly installed one
should be used by configure [and not the compiler default]
Satish
On Wed, 25 Feb 2015, Satish Balay wrote:
> Looks like you have scalapack 'module' already loaded - so didn't need
> Ideally configure should have a different search [library] list for
> --download-package [or --with-package-dir] vs --with-package=1
> options..
> Satish
> On Wed, 25 Feb 2015, Stefano Zampini wrote:
> > I just configured on a Cray XC40 with downloading MUMPS and Scalapack , and it seems that something is wrong when creating petscvariables. SCALAPACK_LIB is empty and -lscalapack does not appear in PETSC_EXTERNAL_LIB.
> > Attached a configure.log
