[petsc-dev] Mark, what's the rational for keeping the Chebyshev tuning inside GAMG?
Tobin Isaac tisaac at ices.utexas.edu
Wed Feb 25 10:05:10 CST 2015
On Wed, Feb 25, 2015 at 11:02:00AM -0500, Mark Adams wrote:
> On Mon, Feb 23, 2015 at 7:19 AM, Tobin Isaac <tisaac at ices.utexas.edu> wrote:
> > On Sun, Feb 22, 2015 at 07:48:51PM -0700, Jed Brown wrote:
> > > Barry Smith <bsmith at mcs.anl.gov> writes:
> > > >   Jed,
> > > >    Wrong, wrong, wrong. You are looking at the wrong place in the
> > > >    code. (Yes, this is a problem with duplicate code in THREE!
> > > >    places). I am referring to the code around line 795 in gamg.c /* do
> > > >    my own cheby */ which I actually cut and pasted into my previous
> > > >    email. You are referring to the code in agg.c around line 1209
> > > >    which does what you said.
> > > Okay, yes.
> > > >    The code I am referring to computes the estimates used by the
> > > >    smoother on each level and thus forces a bypass of the code in
> > > >    Chebyshev.c it seems completely unneeded to me (aside from maybe
> > > >    the hack for crazy matrices) since Chebyshev.c will do it next
> > > >    automatically anyways.
> > > Yeah. It would be nice to avoid repeating the estimate when the smoother
> > > matches the AMG smoothing.
> > If we just keep the part that calls KSPChebyshevSetEigenvalues()
> > (gamg.c:801) when the smoother PC is Jacobi or SOR, that would
> > accomplish this.  The used would have to recognize what's happening
> > and not call -mg_levels_ksp_chebysev_estimate_eigenvalues, which would
> > recompute/override the values that gamg sets.
> That is a reasonable approach.
> > As for crazy matrices, I think the most general solution is for
> > KSPChebyshev to try a MatProjectDirichlet(Mat,Vec) method on the rhs
> > it uses for estimation.
> That sounds promising.  Is that basically the same code that I have?
We could make what you have (finding rows with just diagonals) the
default.  For, e.g., vector-valued problems with unaligned partial
Dirichlet conditions, the user could specify something else.
  Toby
> >   Toby
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150225/ce2a1b23/attachment.sig>
