[petsc-dev] GAMG broken in master
Mark Adams mfadams at lbl.gov
Fri Feb 20 14:19:57 CST 2015
Whoops did not configure.
On Fri, Feb 20, 2015 at 3:17 PM, Mark Adams <mfadams at lbl.gov> wrote:
> Humm, I'm not seeing this...
> 15:13 1 mark/gamg-serial ~/Codes/petsc/src/ksp/ksp/examples/tutorials$
> mpirun  -n 1 ./ex45 -da_refine 3 -pc_type gamg -ksp_monitor -ksp_view
> -log_summary -pc_gamg_coarse_eq_limit 200
>         [0]PCSetUp_GAMG level 0 N=117649, n data rows=1, n data cols=1,
> nnz/row (ave)=6, np=1
>         [0]PCGAMGFilterGraph 91.528% nnz after filtering, with threshold
> 0, 6.87755 nnz ave. (N=117649)
> [0]PCGAMGCoarsen_AGG square graph
> [0]PCGAMGCoarsen_AGG coarsen graph
>         [0]maxIndSetAgg removed 572 of 117649 vertices. (572 local)  16587
> selected.
>                 [0]PCGAMGProlongator_AGG New grid 16587 nodes
>                         PCGAMGOptprol_AGG smooth P0: max
> eigen=1.952686e+00 min=9.933674e-03 PC=jacobi
>                 [0]PCSetUp_GAMG 1) N=16587, n data cols=1, nnz/row
> (ave)=30, 1 active pes
>         [0]PCGAMGFilterGraph 84.7708% nnz after filtering, with threshold
> 0, 30.1631 nnz ave. (N=16587)
>         [0]maxIndSetAgg removed 0 of 16587 vertices. (0 local)  353
> selected.
>                 [0]PCGAMGProlongator_AGG New grid 353 nodes
> eigen=1.393979e+00 min=2.197135e-02 PC=jacobi
>                 [0]PCSetUp_GAMG 2) N=353, n data cols=1, nnz/row (ave)=47,
> 1 active pes
>         [0]PCGAMGFilterGraph 99.7358% nnz after filtering, with threshold
> 0, 47.1756 nnz ave. (N=353)
>         [0]maxIndSetAgg removed 0 of 353 vertices. (0 local)  3 selected.
>                 [0]PCGAMGProlongator_AGG New grid 3 nodes
> eigen=1.983212e+00 min=2.830095e-01 PC=jacobi
>                 [0]PCSetUp_GAMG 3) N=3, n data cols=1, nnz/row (ave)=3, 1
> active pes
>         [0]PCSetUp_GAMG 4 levels, grid complexity = 1.63892
>   0 KSP Residual norm 2.706652282076e+02
>   1 KSP Residual norm 4.940773628648e+01
>   2 KSP Residual norm 3.718259719599e+00
>   3 KSP Residual norm 2.082059791607e-01
>   4 KSP Residual norm 1.700581360081e-02
>   5 KSP Residual norm 9.430563655174e-04
> On Wed, Feb 18, 2015 at 11:06 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   Hmm, it seems GAMG is only doing 2 levels in master for all problems?
> ksp/ex54 seems to do three levels (with -ne 149) with one proc?
> I'll try
>> ./ex29 -da_refine 8 -pc_type gamg -ksp_view
>> uses only two levels. Makes no sense.
>>  Did someone break it?
>> > On Feb 18, 2015, at 9:48 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> >  Mark,
>> >   When I run ksp/ksp/examples/tutorials/ex45 I get a VERY large coarse
>> problem. It seems to ignore the -pc_gamg_coarse_eq_limit 200 argument. Any
>> idea what is going on?
>> >   Thanks
>> >    Barry
>> > $ ./ex45 -da_refine 3 -pc_type gamg -ksp_monitor -ksp_view -log_summary
>> >  0 KSP Residual norm 2.790769524030e+02
>> >  1 KSP Residual norm 4.484052193577e+01
>> >  2 KSP Residual norm 2.409368790441e+00
>> >  3 KSP Residual norm 1.553421589919e-01
>> >  4 KSP Residual norm 9.821441923699e-03
>> >  5 KSP Residual norm 5.610434857134e-04
>> > KSP Object: 1 MPI processes
>> >  type: gmres
>> >    GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>> Orthogonalization with no iterative refinement
>> >    GMRES: happy breakdown tolerance 1e-30
>> >  maximum iterations=10000
>> >  tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>> >  left preconditioning
>> >  using nonzero initial guess
>> >  using PRECONDITIONED norm type for convergence test
>> > PC Object: 1 MPI processes
>> >  type: gamg
>> >    MG: type is MULTIPLICATIVE, levels=2 cycles=v
>> >      Cycles per PCApply=1
>> >      Using Galerkin computed coarse grid matrices
>> >  Coarse grid solver -- level -------------------------------
>> >    KSP Object:    (mg_coarse_)     1 MPI processes
>> >      type: gmres
>> >      maximum iterations=1, initial guess is zero
>> >      using NONE norm type for convergence test
>> >    PC Object:    (mg_coarse_)     1 MPI processes
>> >      type: bjacobi
>> >        block Jacobi: number of blocks = 1
>> >        Local solve is same for all blocks, in the following KSP and PC
>> objects:
>> >        KSP Object:        (mg_coarse_sub_)         1 MPI processes
>> >          type: preonly
>> >        PC Object:        (mg_coarse_sub_)         1 MPI processes
>> >          type: lu
>> >            LU: out-of-place factorization
>> >            tolerance for zero pivot 2.22045e-14
>> >            using diagonal shift on blocks to prevent zero pivot
>> [INBLOCKS]
>> >            matrix ordering: nd
>> >            factor fill ratio given 5, needed 36.4391
>> >              Factored matrix follows:
>> >                Mat Object:                 1 MPI processes
>> >                  type: seqaij
>> >                  rows=16587, cols=16587
>> >                  package used to perform factorization: petsc
>> >                  total: nonzeros=1.8231e+07, allocated
>> nonzeros=1.8231e+07
>> >                  total number of mallocs used during MatSetValues calls
>> =0
>> >                    not using I-node routines
>> >          linear system matrix = precond matrix:
>> >            type: seqaij
>> >            total: nonzeros=500315, allocated nonzeros=500315
>> >            total number of mallocs used during MatSetValues calls =0
>> >        type: seqaij
>> >  Down solver (pre-smoother) on level 1 -------------------------------
>> >    KSP Object:    (mg_levels_1_)     1 MPI processes
>> >      type: chebyshev
>> >        Chebyshev: eigenvalue estimates:  min = 0.0976343, max = 2.05032
>> >      maximum iterations=2
>> >    PC Object:    (mg_levels_1_)     1 MPI processes
>> >      type: sor
>> >        SOR: type = local_symmetric, iterations = 1, local iterations =
>> 1, omega = 1
>> >        type: seqaij
>> >        rows=117649, cols=117649
>> >        total: nonzeros=809137, allocated nonzeros=809137
>> >  Up solver (post-smoother) same as down solver (pre-smoother)
>> >    type: seqaij
>> > Residual norm 3.81135e-05
>> > ***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r
>> -fCourier9' to print this document            ***
>> > ---------------------------------------------- PETSc Performance
>> Summary: ----------------------------------------------
>> > ./ex45 on a arch-opt named Barrys-MacBook-Pro.local with 1 processor,
>> by barrysmith Wed Feb 18 21:38:03 2015
>> > Using Petsc Development GIT revision: v3.5.3-1998-geddef31  GIT Date:
>> 2015-02-18 11:05:09 -0600
>> >                         Max       Max/Min        Avg      Total
>> > Time (sec):           1.103e+01      1.00000   1.103e+01
>> > Objects:              9.200e+01      1.00000   9.200e+01
>> > Flops:                1.756e+10      1.00000   1.756e+10  1.756e+10
>> > Flops/sec:            1.592e+09      1.00000   1.592e+09  1.592e+09
>> > MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
>> > MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
>> > MPI Reductions:       0.000e+00      0.00000
>> > Flop counting convention: 1 flop = 1 real number operation of type
>> (multiply/divide/add/subtract)
>> >                            e.g., VecAXPY() for real vectors of length N
>> --> 2N flops
>> >                            and VecAXPY() for complex vectors of length
>> N --> 8N flops
>> > Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages
>> ---  -- Message Lengths --  -- Reductions --
>> >                        Avg     %Total     Avg     %Total   counts
>>  %Total     Avg         %Total   counts   %Total
>> > 0:      Main Stage: 1.1030e+01 100.0%  1.7556e+10 100.0%  0.000e+00
>>  0.0%  0.000e+00        0.0%  0.000e+00   0.0%
>> > See the 'Profiling' chapter of the users' manual for details on
>> interpreting output.
>> > Phase summary info:
>> >   Count: number of times phase was executed
>> >   Time and Flops: Max - maximum over all processors
>> >                   Ratio - ratio of maximum to minimum over all
>> processors
>> >   Mess: number of messages sent
>> >   Avg. len: average message length (bytes)
>> >   Reduct: number of global reductions
>> >   Global: entire computation
>> >   Stage: stages of a computation. Set stages with PetscLogStagePush()
>> and PetscLogStagePop().
>> >      %T - percent time in this phase         %F - percent flops in this
>> phase
>> >      %M - percent messages in this phase     %L - percent message
>> lengths in this phase
>> >      %R - percent reductions in this phase
>> >   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time
>> > Event                Count      Time (sec)     Flops
>>          --- Global ---  --- Stage ---   Total
>> >                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len
>> Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
>> > --- Event Stage 0: Main Stage
>> > KSPGMRESOrthog        21 1.0 8.8868e-03 1.0 3.33e+07 1.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3752
>> > KSPSetUp               5 1.0 4.3986e-03 1.0 0.00e+00 0.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> > KSPSolve               1 1.0 1.0995e+01 1.0 1.76e+10 1.0 0.0e+00
>> 0.0e+00 0.0e+00100100  0  0  0 100100  0  0  0  1596
>> > VecMDot               21 1.0 4.7335e-03 1.0 1.67e+07 1.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3522
>> > VecNorm               30 1.0 9.4804e-04 1.0 4.63e+06 1.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  4887
>> > VecScale              29 1.0 7.8293e-04 1.0 2.20e+06 1.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2809
>> > VecCopy               14 1.0 7.7058e-04 1.0 0.00e+00 0.0 0.0e+00
>> > VecSet               102 1.0 1.4530e-02 1.0 0.00e+00 0.0 0.0e+00
>> > VecAXPY                9 1.0 3.8154e-04 1.0 9.05e+05 1.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2372
>> > VecAYPX               48 1.0 5.6449e-03 1.0 7.06e+06 1.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1251
>> > VecAXPBYCZ            24 1.0 4.0700e-03 1.0 1.41e+07 1.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3469
>> > VecMAXPY              29 1.0 5.1512e-03 1.0 2.04e+07 1.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3960
>> > VecAssemblyBegin       1 1.0 6.7055e-08 1.0 0.00e+00 0.0 0.0e+00
>> > VecAssemblyEnd         1 1.0 8.1025e-08 1.0 0.00e+00 0.0 0.0e+00
>> > VecPointwiseMult      11 1.0 1.8083e-03 1.0 1.29e+06 1.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   716
>> > VecSetRandom           1 1.0 1.7628e-03 1.0 0.00e+00 0.0 0.0e+00
>> > VecNormalize          29 1.0 1.7100e-03 1.0 6.60e+06 1.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  3858
>> > MatMult               58 1.0 5.0949e-02 1.0 8.39e+07 1.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1647
>> > MatMultAdd             6 1.0 5.2584e-03 1.0 5.01e+06 1.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   952
>> > MatMultTranspose       6 1.0 6.1330e-03 1.0 5.01e+06 1.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   816
>> > MatSolve              12 1.0 2.0657e-01 1.0 4.37e+08 1.0 0.0e+00
>> 0.0e+00 0.0e+00  2  2  0  0  0   2  2  0  0  0  2117
>> > MatSOR                36 1.0 7.1355e-02 1.0 5.84e+07 1.0 0.0e+00
>> 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0   818
>> > MatLUFactorSym         1 1.0 3.4310e-01 1.0 0.00e+00 0.0 0.0e+00
>> 0.0e+00 0.0e+00  3  0  0  0  0   3  0  0  0  0     0
>> > MatLUFactorNum         1 1.0 9.8038e+00 1.0 1.69e+10 1.0 0.0e+00
>> 0.0e+00 0.0e+00 89 96  0  0  0  89 96  0  0  0  1721
>> > MatConvert             1 1.0 5.6955e-03 1.0 0.00e+00 0.0 0.0e+00
>> > MatScale               3 1.0 2.7223e-03 1.0 2.45e+06 1.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   901
>> > MatResidual            6 1.0 6.2142e-03 1.0 9.71e+06 1.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1562
>> > MatAssemblyBegin      12 1.0 2.7413e-06 1.0 0.00e+00 0.0 0.0e+00
>> > MatAssemblyEnd        12 1.0 2.4857e-02 1.0 0.00e+00 0.0 0.0e+00
>> > MatGetRow         470596 1.0 2.4337e-02 1.0 0.00e+00 0.0 0.0e+00
>> > MatGetRowIJ            1 1.0 2.3254e-03 1.0 0.00e+00 0.0 0.0e+00
>> > MatGetOrdering         1 1.0 1.7668e-02 1.0 0.00e+00 0.0 0.0e+00
>> > MatCoarsen             1 1.0 8.5790e-03 1.0 0.00e+00 0.0 0.0e+00
>> > MatView                5 1.0 2.2273e-04 1.0 0.00e+00 0.0 0.0e+00
>> > MatAXPY                1 1.0 1.8864e-02 1.0 0.00e+00 0.0 0.0e+00
>> > MatMatMult             1 1.0 2.4513e-02 1.0 2.03e+06 1.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    83
>> > MatMatMultSym          1 1.0 1.7885e-02 1.0 0.00e+00 0.0 0.0e+00
>> > MatMatMultNum          1 1.0 6.6144e-03 1.0 2.03e+06 1.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   307
>> > MatPtAP                1 1.0 1.1460e-01 1.0 1.30e+07 1.0 0.0e+00
>> 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0   114
>> > MatPtAPSymbolic        1 1.0 4.6803e-02 1.0 0.00e+00 0.0 0.0e+00
>> > MatPtAPNumeric         1 1.0 6.7781e-02 1.0 1.30e+07 1.0 0.0e+00
>> 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0   192
>> > MatTrnMatMult          1 1.0 9.1702e-02 1.0 1.02e+07 1.0 0.0e+00
>> 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0   111
>> > MatTrnMatMultSym       1 1.0 6.0173e-02 1.0 0.00e+00 0.0 0.0e+00
>> 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
>> > MatTrnMatMultNum       1 1.0 3.1526e-02 1.0 1.02e+07 1.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   324
>> > MatGetSymTrans         2 1.0 4.2753e-03 1.0 0.00e+00 0.0 0.0e+00
>> > PCGAMGgraph_AGG        1 1.0 6.9175e-02 1.0 1.62e+06 1.0 0.0e+00
>> 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0    23
>> > PCGAMGcoarse_AGG       1 1.0 1.1130e-01 1.0 1.02e+07 1.0 0.0e+00
>> 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0    92
>> > PCGAMGProl_AGG         1 1.0 2.9380e-02 1.0 0.00e+00 0.0 0.0e+00
>> > PCGAMGPOpt_AGG         1 1.0 9.1377e-02 1.0 5.15e+07 1.0 0.0e+00
>> 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0   564
>> > PCSetUp                2 1.0 1.0587e+01 1.0 1.69e+10 1.0 0.0e+00
>> 0.0e+00 0.0e+00 96 97  0  0  0  96 97  0  0  0  1601
>> > PCSetUpOnBlocks        6 1.0 1.0165e+01 1.0 1.69e+10 1.0 0.0e+00
>> 0.0e+00 0.0e+00 92 96  0  0  0  92 96  0  0  0  1660
>> > PCApply                6 1.0 1.0503e+01 1.0 1.75e+10 1.0 0.0e+00
>> 0.0e+00 0.0e+00 95 99  0  0  0  95 99  0  0  0  1662
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150220/f5f53245/attachment.html>
