[petsc-dev] CUDA guys, stuff still broken in master/next
Dominic Meiser
dmeiser at txcorp.com
Thu Feb 19 14:11:44 CST 2015
Hi Karl,
Have you had a chance to look into this?
Cheers,
Dominic
On 02/19/2015 12:46 PM, Barry Smith wrote:
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/02/18/examples_master_arch-cuda-double_bb-proxy.log
> 1,2c1,150
> < Linear stokes_ solve converged due to CONVERGED_RTOL iterations 16
> < 9.0909e-02 1.9273e-03 2.9842e-04 4.8732e-03
>> Linear stokes_ solve converged due to CONVERGED_ATOL iterations 0
>> 9.0909e-02 7.9577e-02 1.7911e-02 2.9249e-01
>> [0]Total space allocated 64 bytes
>> [ 0]32 bytes VecCreate_Seq_Private() line 1250 in /home/balay/petsc.clone/src/vec/vec/impls/seq/bvec2.c
>> [0] VecCreate_Seq_Private() line 1250 in /home/balay/petsc.clone/src/vec/vec/impls/seq/bvec2.c
>> [0] VecCreate_SeqCUSP() line 1942 in /home/balay/petsc.clone/src/vec/vec/impls/seq/seqcusp/veccusp.cu
>> [0] VecSetType() line 38 in /home/balay/petsc.clone/src/vec/vec/interface/vecreg.c
>> [0] VecCreate_CUSP() line 242 in /home/balay/petsc.clone/src/vec/vec/impls/mpi/mpicusp/mpicusp.cu
>> [0] PCSetUp_BJacobi_Singleblock() line 783 in /home/balay/petsc.clone/src/ksp/pc/impls/bjacobi/bjacobi.c
>> [0] PCSetUp_BJacobi() line 24 in /home/balay/petsc.clone/src/ksp/pc/impls/bjacobi/bjacobi.c
>> [0] PCSetUp() line 882 in /home/balay/petsc.clone/src/ksp/pc/interface/precon.c
>> [0] KSPSetUp() line 245 in /home/balay/petsc.clone/src/ksp/ksp/interface/itfunc.c
>> [0] KSPSolve() line 492 in /home/balay/petsc.clone/src/ksp/ksp/interface/itfunc.c
>> [0] PCApply_BJacobi_Multiproc() line 1178 in /home/balay/petsc.clone/src/ksp/pc/impls/bjacobi/bjacobi.c
>> [0] PCApply() line 430 in /home/balay/petsc.clone/src/ksp/pc/interface/precon.c
>> [0] KSP_PCApply() line 233 in /home/balay/petsc.clone/include/petsc-private/kspimpl.h
>> [0] KSPInitialResidual() line 44 in /home/balay/petsc.clone/src/ksp/ksp/interface/itres.c
>> [0] KSPSolve_GMRES() line 224 in /home/balay/petsc.clone/src/ksp/ksp/impls/gmres/gmres.c
>> [0] solve_stokes_2d_coupled() line 1143 in /home/balay/petsc.clone/src/ksp/ksp/examples/tutorials/ex43.c
>> [1]Total space allocated 64 bytes
>> [ 1]32 bytes VecCreate_Seq_Private() line 1250 in /home/balay/petsc.clone/src/vec/vec/impls/seq/bvec2.c
>> [1] VecCreate_Seq_Private() line 1250 in /home/balay/petsc.clone/src/vec/vec/impls/seq/bvec2.c
>> [1] VecCreate_SeqCUSP() line 1942 in /home/balay/petsc.clone/src/vec/vec/impls/seq/seqcusp/veccusp.cu
>> [1] VecSetType() line 38 in /home/balay/petsc.clone/src/vec/vec/interface/vecreg.c
>> [1] VecCreate_CUSP() line 242 in /home/balay/petsc.clone/src/vec/vec/impls/mpi/mpicusp/mpicusp.cu
>> [1] PCSetUp_BJacobi_Singleblock() line 783 in /home/balay/petsc.clone/src/ksp/pc/impls/bjacobi/bjacobi.c
>> [1] PCSetUp_BJacobi() line 24 in /home/balay/petsc.clone/src/ksp/pc/impls/bjacobi/bjacobi.c
>> [1] PCSetUp() line 882 in /home/balay/petsc.clone/src/ksp/pc/interface/precon.c
>> [1] KSPSetUp() line 245 in /home/balay/petsc.clone/src/ksp/ksp/interface/itfunc.c
>> [1] KSPSolve() line 492 in /home/balay/petsc.clone/src/ksp/ksp/interface/itfunc.c
>> [1] PCApply_BJacobi_Multiproc() line 1178 in /home/balay/petsc.clone/src/ksp/pc/impls/bjacobi/bjacobi.c
>> [1] PCApply() line 430 in /home/balay/petsc.clone/src/ksp/pc/interface/precon.c
>> [1] KSP_PCApply() line 233 in /home/balay/petsc.clone/include/petsc-private/kspimpl.h
>> [1] KSPInitialResidual() line 44 in /home/balay/petsc.clone/src/ksp/ksp/interface/itres.c
>> [1] KSPSolve_GMRES() line 224 in /home/balay/petsc.clone/src/ksp/ksp/impls/gmres/gmres.c
>> [1] solve_stokes_2d_coupled() line 1143 in /home/balay/petsc.clone/src/ksp/ksp/examples/tutorials/ex43.c
>> [2]Total space allocated 64 bytes
>> [ 2]32 bytes VecCreate_Seq_Private() line 1250 in /home/balay/petsc.clone/src/vec/vec/impls/seq/bvec2.c
>> [2] VecCreate_Seq_Private() line 1250 in /home/balay/petsc.clone/src/vec/vec/impls/seq/bvec2.c
>> [2] VecCreate_SeqCUSP() line 1942 in /home/balay/petsc.clone/src/vec/vec/impls/seq/seqcusp/veccusp.cu
>> [2] VecSetType() line 38 in /home/balay/petsc.clone/src/vec/vec/interface/vecreg.c
>> [2] VecCreate_CUSP() line 242 in /home/balay/petsc.clone/src/vec/vec/impls/mpi/mpicusp/mpicusp.cu
>> [2] PCSetUp_BJacobi_Singleblock() line 783 in /home/balay/petsc.clone/src/ksp/pc/impls/bjacobi/bjacobi.c
>> [2] PCSetUp_BJacobi() line 24 in /home/balay/petsc.clone/src/ksp/pc/impls/bjacobi/bjacobi.c
>> [2] PCSetUp() line 882 in /home/balay/petsc.clone/src/ksp/pc/interface/precon.c
>> [2] KSPSetUp() line 245 in /home/balay/petsc.clone/src/ksp/ksp/interface/itfunc.c
>> [2] KSPSolve() line 492 in /home/balay/petsc.clone/src/ksp/ksp/interface/itfunc.c
>> [2] PCApply_BJacobi_Multiproc() line 1178 in /home/balay/petsc.clone/src/ksp/pc/impls/bjacobi/bjacobi.c
>> [2] PCApply() line 430 in /home/balay/petsc.clone/src/ksp/pc/interface/precon.c
>> [2] KSP_PCApply() line 233 in /home/balay/petsc.clone/include/petsc-private/kspimpl.h
>> [2] KSPInitialResidual() line 44 in /home/balay/petsc.clone/src/ksp/ksp/interface/itres.c
>> [2] KSPSolve_GMRES() line 224 in /home/balay/petsc.clone/src/ksp/ksp/impls/gmres/gmres.c
>> [2] solve_stokes_2d_coupled() line 1143 in /home/balay/petsc.clone/src/ksp/ksp/examples/tutorials/ex43.c
>> [3]Total space allocated 64 bytes
>> [ 3]32 bytes VecCreate_Seq_Private() line 1250 in /home/balay/petsc.clone/src/vec/vec/impls/seq/bvec2.c
>> [3] VecCreate_Seq_Private() line 1250 in /home/balay/petsc.clone/src/vec/vec/impls/seq/bvec2.c
>> [3] VecCreate_SeqCUSP() line 1942 in /home/balay/petsc.clone/src/vec/vec/impls/seq/seqcusp/veccusp.cu
>> [3] VecSetType() line 38 in /home/balay/petsc.clone/src/vec/vec/interface/vecreg.c
>> [3] VecCreate_CUSP() line 242 in /home/balay/petsc.clone/src/vec/vec/impls/mpi/mpicusp/mpicusp.cu
>> [3] PCSetUp_BJacobi_Singleblock() line 783 in /home/balay/petsc.clone/src/ksp/pc/impls/bjacobi/bjacobi.c
>> [3] PCSetUp_BJacobi() line 24 in /home/balay/petsc.clone/src/ksp/pc/impls/bjacobi/bjacobi.c
>> [3] PCSetUp() line 882 in /home/balay/petsc.clone/src/ksp/pc/interface/precon.c
>> [3] KSPSetUp() line 245 in /home/balay/petsc.clone/src/ksp/ksp/interface/itfunc.c
>> [3] KSPSolve() line 492 in /home/balay/petsc.clone/src/ksp/ksp/interface/itfunc.c
>> [3] PCApply_BJacobi_Multiproc() line 1178 in /home/balay/petsc.clone/src/ksp/pc/impls/bjacobi/bjacobi.c
>> [3] PCApply() line 430 in /home/balay/petsc.clone/src/ksp/pc/interface/precon.c
>> [3] KSP_PCApply() line 233 in /home/balay/petsc.clone/include/petsc-private/kspimpl.h
>> [3] KSPInitialResidual() line 44 in /home/balay/petsc.clone/src/ksp/ksp/interface/itres.c
>> [3] KSPSolve_GMRES() line 224 in /home/balay/petsc.clone/src/ksp/ksp/impls/gmres/gmres.c
>> [3] solve_stokes_2d_coupled() line 1143 in /home/balay/petsc.clone/src/ksp/ksp/examples/tutorials/ex43.c
> Possible problem with ex43_bjacobi, diffs above
> 1,2c1,150
> Possible problem with ex43_bjacobi_baij, diffs above
> 46c46
> < 44 KSP Residual norm 5.15089e-05
>> 44 KSP Residual norm 5.1509e-05
> Possible problem with ex49_1, diffs above
> 2,14c2,16
> < 0 KSP Residual norm 4.5784
> < 1 KSP Residual norm 0.264677
> < 2 KSP Residual norm 0.067428
> < 3 KSP Residual norm 0.0188871
> < 4 KSP Residual norm 0.00960792
> < 5 KSP Residual norm 0.00522938
Dominic Meiser
Tech-X Corporation
5621 Arapahoe Avenue
Boulder, CO 80303
USA
Telephone: 303-996-2036
Fax: 303-448-7756
www.txcorp.com
