[petsc-dev] PetscSSLDestroyContext
Mark Adams
mfadams at lbl.gov
Tue Feb 17 13:15:52 CST 2015
I pulled and it is OK now.
On Tue, Feb 17, 2015 at 12:32 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Please send configure.log and make.log When do you get this error?
> Making the PETSc library? Making the PETSc test? Making application?
> Yes you can configure with --with-ssl=0 but please send all the data
> first so we can see what goes wrong.
> Barry
> > On Feb 17, 2015, at 10:59 AM, Mark Adams <mfadams at lbl.gov> wrote:
> > I started getting this error on Edison at NERSC. Should I configure
> with --with-ssl=0 ?
> > Mark
> /global/homes/m/madams/petsc_master/arch-xc30-opt64-intel/lib/libpetsc.a(send.o):
> In function `PetscOpenSocket':
> /global/u2/m/madams/petsc_master/src/sys/classes/viewer/impls/socket/send.c:(.text+0xc8):
> warning: Using 'gethostbyname' in statically linked applications requires
> at runtime the shared libraries from the glibc version used for linking
> /global/homes/m/madams/petsc_master/arch-xc30-opt64-intel/lib/libpetsc.a(client.o):
> In function `PetscSSLDestroyContext':
> /global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x12):
> undefined reference to `SSL_CTX_free'
> In function `PetscHTTPSRequest':
> /global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x60):
> undefined reference to `SSL_write'
> /global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x6e):
> undefined reference to `SSL_get_error'
> /global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0xcb):
> undefined reference to `SSL_read'
> /global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0xdb):
> /global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0xef):
> undefined reference to `SSL_shutdown'
> /global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x20d):
> undefined reference to `SSL_free'
> In function `PetscHTTPSConnect':
> /global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x1b8e):
> undefined reference to `SSL_new'
> /global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x1b9b):
> undefined reference to `BIO_new_socket'
> /global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x1ba9):
> undefined reference to `SSL_set_bio'
> /global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x1bb1):
> undefined reference to `SSL_connect'
> In function `PetscSSLInitializeContext':
> /global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x24a1):
> undefined reference to `SSLv23_method'
> /global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x24a9):
> undefined reference to `SSL_CTX_new'
> /global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x24c0):
> undefined reference to `SSL_CTX_ctrl'
> /global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x24d0):
> undefined reference to `SSL_library_init'
> /global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x24d5):
> undefined reference to `SSL_load_error_strings'
> /global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x24e3):
> undefined reference to `BIO_new_fp'
> > /usr/bin/ld: link errors found, deleting executable `xgca'
> > make: *** [xgca] Error 1
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150217/5d56c31f/attachment.html>
