[petsc-dev] major git problem!
    Barry Smith
    bsmith at mcs.anl.gov
    Mon Feb 16 18:02:02 CST 2015
  So removed ALL the logs and it stopped bitching
$ rm -rf .git/logs/
~/Src/petsc (master<) arch-mpich
$ git fetch
From bitbucket.org:petsc/petsc
 * [new branch]      balay/update-scotch_6.0.3 -> origin/balay/update-scotch_6.0.3
  whatever the logs are
> On Feb 16, 2015, at 5:58 PM, Jed Brown <jed at jedbrown.org> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>> $ git pull
>> error: There are still logs under '.git/logs/refs/remotes/origin/balay/update-scotch_6.0.3'
>> ! [new branch]      balay/update-scotch_6.0.3 -> origin/balay/update-scotch_6.0.3  (unable to update local ref)
>> If I delete that directory .git/logs/refs/remotes/origin/balay/update-scotch_6.0.3 I still get the error message again
> I can't reproduce.  Can you "git fetch"?
